Hello, I am working on a project with an Infrared Controller and neopixels on an arduino Uno board. The goal of the project (for now) is to be able to choose between red, blue and green and a rainbow effect. The 3 first colors work well, no problem there. The rainbow effect: it does work normally, but the led strip doesnt turn off when i press on the button. It seems like i need to wait for the rainbow animation to stop ( yeah, i also want to fix that, so that it works till i click on another button) before any of the other buttons have any effect on the arduino. The do get ‘seen’ by the arduino thanks to a led on the arduino that turns on when the it receives a signal, but there isnt any other action. Once the effect is finished, the program works again normally.
For more info, just answer to this post, I will try answering back ASAP.
#include <IRremote.h> //include IR reciever library
#include <Adafruit_NeoPixel.h> // include Neopixel library
const int RECV_PIN = 7; // set the IR receiver to pin 7
IRrecv irrecv(RECV_PIN); // stuff from the IR library
decode_results results; // stuff from the IR library
#define PIN 8 // set the Neopixel to pin 8
#define N_LEDS 30 // set the Neopixel amount of leds
Adafruit_NeoPixel strip = Adafruit_NeoPixel(N_LEDS, PIN, NEO_GRB + NEO_KHZ800); //call the Neopixel strip
uint32_t red = strip.Color(255, 0, 0); // these are just some colors i want to have for buttons on the controller
uint32_t green = strip.Color(0, 255, 0); // these are just some colors i want to have for buttons on the controller
uint32_t blue = strip.Color(0, 0, 255); // these are just some colors i want to have for buttons on the controller
int rep = 0; // the variable I thought of using to tell the Arduino when to stop the Rainbow effect
void setup(){
irrecv.enableIRIn(); // some IR stuff again
irrecv.blink13(true); // some IR stuff again
strip.begin(); //resetting the Neopixels to off at the beginnig of the program
strip.show(); // strip.show to update the strip
* This rainbow effect wasnt programmed by me because I had been struggling for 2 weeks on making one
* I did force myself to understand the whole of it
* even though it isnt fully clear to me
* I hope it will for you guys
void rainbow(uint8_t wait) {
uint16_t i, j;
for(j=0; j<256; j++) {
for(i=0; i<strip.numPixels(); i++) { //this is used to give the 'rolling colors' effect (i think)
strip.setPixelColor(i, Wheel((i*1+j) & 255));
strip.show();
delay(wait);
void loop(){
/*For the buttons 1, 2, 3 and PWR , 'switch and 'case' are only for the IR receiver
* 1) strip.clear to make sure ther isnt any color left from before
* 2) strip.fill(red) to fill the strip in the predefined color
* 3) rep = 1 to make sure the rainbow effect is off (i put the rainbow in a if statement (if rep = 0 then do rainbow effect)
* 4) strip.show to update the strip
if (irrecv.decode(&results)){
switch(results.value){
case 0xFF30CF: //Keypad button "1"
strip.clear();
strip.fill(red);
rep = 1 ;
strip.show();
case 0xFF18E7: //Keypad button "2"
strip.clear();
strip.fill(green);
rep = 1;
strip.show();
case 0xFF7A85: //Keypad button "3"
strip.clear();
strip.fill(blue);
rep = 1;
strip.show();
case 0xFFA25D: //Keypad button "PWR"
strip.clear();
rep = 1;
strip.show();
case 0xFF9867: //Keypad button "Random"
strip.clear(); // clear the strip of any ongoing colors
rep = 0;
if(rep == 0) { // if statement to control the rainbow effect (see also the other buttons to know what is the value of rep)
rainbow(30); // the rainbow effect command line
strip.show(); // updating the strip
else {
strip.clear(); // 'turning' the strip 'off'
irrecv.resume(); // more IR reciever code
// this last part is only programm to choose a color.
// I dont think it has to do anyting with my problem. I someone could give a short explanation in the comments,
// i woulndt mind it though
uint32_t Wheel(byte WheelPos) {
if(WheelPos < 85) {
return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
else if(WheelPos < 170) {
WheelPos -= 85;
return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
else {
WheelPos -= 170;
return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
