i'm trying to make a bedsidelight/alarmclock/wakeuplight.
for now this is my code:
#include <Wire.h>
#include <Time.h>
#include <TimeLib.h>
#include "Adafruit_LEDBackpack.h"
#include "Adafruit_GFX.h"
#include "RTClib.h"
#ifdef __AVR__
#include <avr/power.h>
#endif
#define PIN 6
#define NUM_LEDS 16
#define BRIGHTNESS 50
RTC_DS1307 RTC;
Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUM_LEDS, PIN, NEO_GRBW + NEO_KHZ800);
int gamma[] = {
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 1, 1, 1,
1, 1, 1, 1, 1, 1, 1, 1, 1, 2, 2, 2, 2, 2, 2, 2,
2, 3, 3, 3, 3, 3, 3, 3, 4, 4, 4, 4, 4, 5, 5, 5,
5, 6, 6, 6, 6, 7, 7, 7, 7, 8, 8, 8, 9, 9, 9, 10,
10, 10, 11, 11, 11, 12, 12, 13, 13, 13, 14, 14, 15, 15, 16, 16,
17, 17, 18, 18, 19, 19, 20, 20, 21, 21, 22, 22, 23, 24, 24, 25,
25, 26, 27, 27, 28, 29, 29, 30, 31, 32, 32, 33, 34, 35, 35, 36,
37, 38, 39, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 50,
51, 52, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 66, 67, 68,
69, 70, 72, 73, 74, 75, 77, 78, 79, 81, 82, 83, 85, 86, 87, 89,
90, 92, 93, 95, 96, 98, 99,101,102,104,105,107,109,110,112,114,
115,117,119,120,122,124,126,127,129,131,133,135,137,138,140,142,
144,146,148,150,152,154,156,158,160,162,164,167,169,171,173,175,
177,180,182,184,186,189,191,193,196,198,200,203,205,208,210,213,
215,218,220,223,225,228,231,233,236,239,241,244,247,249,252,255 };
Adafruit_7segment disp = Adafruit_7segment();
Wire.begin();
RTC.begin();
if (! RTC.isrunning())
RTC.adjust(DateTime(__DATE__, __TIME__));
//RTC.adjust(DateTime(__TIME__));
disp.begin(0x70);
disp.setBrightness(0);
// This is for Trinket 5V 16MHz, you can remove these three lines if you are not using a Trinket
//#if defined (__AVR_ATtiny85__)
// if (F_CPU == 16000000) clock_prescale_set(clock_div_1);
//#endif
// End of trinket special code
strip.setBrightness(BRIGHTNESS);
strip.begin();
strip.show(); // Initialize all pixels to 'off'
fullRed();
disp.print(getDecimalTime());
disp.drawColon(true);
disp.writeDisplay();
//delay(500);
//disp.drawColon(false);
//disp.writeDisplay();
//delay(500);
int getDecimalTime()
DateTime now = RTC.now();
int decimalTime = now.hour() * 100 + now.minute();
if (now.hour()<1){
disp.print(0);
return decimalTime;
void fullRed() {
tmElements_t tm;
for(uint16_t i=0; i<strip.numPixels(); i++) {
if (now.hour() >= 21 && (now.hour() <= 22)){
strip.setPixelColor(i, strip.Color(255,0,0,0) );
strip.setBrightness(50);
strip.show();}
else if (now.hour() >= 22 && (now.hour() < 24)){
strip.setPixelColor(i, strip.Color(255,255,0,0) );
strip.setBrightness(1);
strip.show();}
else if (now.hour() >= 24 && (now.hour() < 6)){
strip.setPixelColor(i, strip.Color(255,255,255,0) );
strip.show();}
else if (now.hour() >= 6 && (now.hour() < 21)){
strip.setPixelColor(i, strip.Color(204,0,204,0) );
strip.show();}
for now i have a physical button that cut the power on the neopixels, but for the wakeuplight, i need a software solution. How can i make the lights go on on a set time, and at the same time use the button to switch on the light at night (for example).
so in short: switch lights on/off with a button, and the same light go on automaticaly on a set time in the morning, regardless what state the on/off switch is.
Thx in advance.
