Nerf gun circuit
Hello everyone,
I'm working on a circuit to control a nerf gun and I was hoping to get some guidance, as this is my first real electronics project. I think the circuit is pretty good so far, but I want to know whether I'm missing anything. Attached is a picture of the circuit.
Thank you!
Why is one of your diodes labeled Flywheel 2?
What is a pusher?
What kind of 7.4V power supply are you planning?
Specifically, what are Q1 and Q2?
If you used INPUL_PULLUP as the mode, the external resistors on the switches are not needed.
The flywheel2 diode is backwards causing a short when the corresponding motor is powered. And the pusher motor is missing the flywheel diode.
PaulS:
What is a pusher?
The label was misplaced, it was supposed to be on the second wheel. The pusher motor is just a standard DC motor with a mechanical assembly to push darts into the flywheels. The 7.4V power supply is a 2 cell LiPo battery.
groundFungus:
I have updated the schematic to fix these issues.
Updated schematic.
[nitpick] Should have part numbers for the MOSFETs. The MOSFET symbols are for P channel. A schematic should have all of the information required to duplicate the circuit.[/nitpick]
How to post images.
N channel MOSFET symbol
