Nested Derived Classes
Hi:
I am attempting to access a member from a base class as follows:
class A { public: int base_member() {....does stuff }; }
class B: public A { }
class C: public B { public : int doThing() { int rc=base_member();) }
Each of the classes are kept in separate libraries. The compiler has -I directives for each directory containing class A, B, C.
I am unable to complete the compile as the doThing() member is not able to see base_member().
I am able to do this with a standard GNU compiler. Is there a restriction/Limitation with the avr_g++?
Thanks!!
Peter
Problem found:
in CPP extension didn’t use >::method convention.
