nested folders
Greetings,
Sorry if this was reported before, I searched a little but but found nothing.
I can create nested folders, but when I create a sketch, only the last level of the nested folders will remain.
Ex,
Create some nested folers
Folder1
Folder2
Folder3
Now if you create a sketch in Folder3, it will remove Folder1 and 2 and you'll end up with
Folder3
sketch_xxxxx
The limit is currently 3 as you have found for bested folders.
This also applies to libraries.
I don't think is the limit?
A limit would prevent me to create more folders if there are already 3 nested folders, and would not remove everything else that is below the last folder.
If you have a folder1 with sketches, and then you create a folder2, and add a sketch to folder 2, folder 1 and everything in it except folder2 will be deleted, all you can see is folder2
The current nested limit does that.
It is not elegant in the way it deals with nested items but currently that is it.
I am pretty certain its also on a quite long list of items that need to be tidied up a little.
Hi @puiucristian,
the problem is that a folder does not exists for real, unless you put a sketch in it (if you create a folder without nothing in it and refresh the browser you'll not find it), so the behavior is a little buggy at the moment. We'll try to improve it as soon as possible
