Hello,
i am trying to shrink my code from this:
[code]
//PT1
digitalWrite(cs1, LOW);
uint16_t rtd1 = max_1.readRTD();
float ratio1 = rtd1;
ratio1 /= 32768;
pt1=max_1.temperature(100, RREF);
Serial.println(pt1);
digitalWrite(cs1, HIGH);
//PT2
digitalWrite(cs2, LOW);
uint16_t rtd2 = max_2.readRTD();
float ratio2 = rtd2;
ratio2 /= 32768;
pt2=max_2.temperature(100, RREF);
Serial.println(pt2);
digitalWrite(cs2, HIGH);
//PT3
digitalWrite(cs3, LOW);
uint16_t rtd3 = max_3.readRTD();
float ratio3 = rtd3;
ratio3 /= 32768;
pt3=max_3.temperature(100, RREF);
Serial.println(pt3);
digitalWrite(cs3, HIGH);
//PT4
digitalWrite(cs4, LOW);
uint16_t rtd4 = max_4.readRTD();
float ratio4 = rtd4;
ratio4 /= 32768;
pt4=max_4.temperature(100, RREF);
Serial.println(pt4);
digitalWrite(cs4, HIGH);
[/code]
to this:
[code]
float readTemp(cs1, rtd1, max_1.readRTD, ratio1, pt1, max_1.temperature);
float readTemp(cs2, rtd2, max_2.readRTD, ratio2, pt2, max_2.temperature);
float readTemp(cs3, rtd3, max_3.readRTD, ratio3, pt3, max_3.temperature);
float readTemp(cs4, rtd4, max_4.readRTD, ratio4, pt4, max_4.temperature);
[/code]
The problem currently is here as i try to declare a function with a function as a parameter, and that
does not not work like this.
[code]
void readTemp(int a, uint16_t b, uint16_t c, float d , float e, uint16_t f){
digitalWrite(a, LOW);
b = c;
d = b;
d /= 32768;
e = f(100, RREF);
Serial.println(e);
digitalWrite(a, HIGH);
[/code]
i get " 'f' cannot be used as a function" error which has to do with pointers i believe but i cant solve it.
Note that i want help with the structure of the functions and the declaration of them and the board is irrelevant as the first/analytical code that i posted is actually working :
This is the whole sketch.
[code]
//#include "SoftwareSerial.h"
#include "SPI.h"
#include "DHT.h"
#include "MS5611.h"
#include "Wire.h"
#include <Arduino.h>
#include <ArduinoJson.h>
#define DHTPIN 40
#define DHTTYPE DHT22
#define P0 1013.25
#include <Adafruit_MAX31865.h>
#define RREF 430.0
// The 'nominal' 0-degrees-C resistance of the sensor
// 100.0 for PT100, 1000.0 for PT1000
#define RNOMINAL 100.0
const int cs1=11,cs2=12,cs3=13,cs4=17;
float t=0,h=0,pt1=0,pt2=0,pt3=0,pt4=0;
long realPressure;
double referencePressure;
DHT dht(DHTPIN, DHTTYPE);
//MS5611
MS5611 ms5611;
//PT100-MAX31865 SETUP
// use hardware SPI, just pass in the CS pin
Adafruit_MAX31865 max_1 = Adafruit_MAX31865(cs1);
Adafruit_MAX31865 max_2 = Adafruit_MAX31865(cs2);
Adafruit_MAX31865 max_3 = Adafruit_MAX31865(cs3);
Adafruit_MAX31865 max_4 = Adafruit_MAX31865(cs4);
b = c;
d = b;
d /= 32768;
e = f(100, RREF);
Serial.println(e);
void setup(void){
Serial1.begin(9600);
SPI.begin();
dht.begin();
u8g2.begin();
u8g2.clearDisplay();
ms5611.begin();
referencePressure = ms5611.readPressure();
max_1.begin(MAX31865_3WIRE);
max_2.begin(MAX31865_3WIRE);
max_3.begin(MAX31865_3WIRE);
max_4.begin(MAX31865_3WIRE);
//dht22
h = dht.readHumidity();
t = dht.readTemperature();
//MS5611
// Read raw values
uint32_t rawPressure = ms5611.readRawPressure();
// Read true Pressure
realPressure = ms5611.readPressure();
float readTemp(cs1, rtd1, max_1.readRTD, ratio1, pt1,max_1.temperature);
float readTemp(cs2, rtd2, max_2.readRTD, ratio2, pt2,max_2.temperature);
float readTemp(cs3, rtd3, max_3.readRTD, ratio3, pt3,max_3.temperature);
float readTemp(cs4, rtd4, max_4.readRTD, ratio4, pt4,max_4.temperature);
StaticJsonBuffer<1024> jsonBuffer;
JsonObject& data = jsonBuffer.createObject();
//Assign collected data to Json Object
data["humidity"] = h;
data["temperature"] = t;
data["pt1"] = pt1;
data["pt2"] = pt2;
data["pt3"] = pt3;
data["pt4"] = pt4;
data["pressure"] = realPressure;
//Send data to NodeMCU
data.printTo(Serial1);
jsonBuffer.clear();
[/code]
Thanks in advance,
Gio.
