Nesting menus on LCD
I'm using the nuelectronics 3310 LCD with this library (http://blog.thiseldo.co.uk/?p=383)
The example provided shows one main menu with each option leading to various demos.
I've changed the menu text and have my first option working fine (it leads to a simple temp display area)
But the second option i need to lead to a second menu, this is the bit i can't figure out.
here is my code so far
Part 1:
#include <OneWire.h>
#include <DallasTemperature.h>
#include <nokia_3310_lcd.h>
// Temp/humidity display using nokia 3310 LCD display shield from nuelectronics.com
// Data wire is plugged into port 2 on the Arduino
#define ONE_WIRE_BUS 2
// Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
//keypad debounce parameter
#define DEBOUNCE_MAX 15
#define DEBOUNCE_ON  10
#define DEBOUNCE_OFF 3
#define NUM_KEYS 5
#define NUM_MENU_ITEM      5
#define NUM_MENU_ITEM1  6
// joystick number
#define UP_KEY 3
#define LEFT_KEY 0
#define CENTER_KEY 1
#define DOWN_KEY 2
#define RIGHT_KEY 4
// Pin used by Backlight, so we can turn it on and off. Pin setup in LCD init function
#define BL_PIN 7
// menu starting points
#define MENU_X      5            // 0-83
#define MENU_Y      0            // 0-5
// adc preset value, represent top value,incl. noise & margin,that the adc reads, when a key is pressed
// set noise & margin = 30 (0.15V@5V)
int  adc_key_val[5] ={
  30, 150, 360, 535, 760 };
// debounce counters
byte button_count[NUM_KEYS];
// button status - pressed/released
byte button_status[NUM_KEYS];
// button on flags for user program
byte button_flag[NUM_KEYS];
  char* shower;
// menu definition
char menu_items[NUM_MENU_ITEM][14]={
  "TEMPERATURE",
  "WATER REQUEST"
void (*menu_funcs[NUM_MENU_ITEM])(void) = {
  temperature,
  waterreq
char menu_items1[NUM_MENU_ITEM1][5]={
  "1",
  "1.5",
  "2",
  "2.5",
  "Bath",
  "None"
void (*menu_funcs1[NUM_MENU_ITEM1])(void) = {
   shower1,
   shower15,
   shower2,
   shower25,
   bath,
   none
char current_menu_item;
int blflag = 1;  // Backlight initially ON
char degree = 0x7b;  // Degree symbol
Nokia_3310_lcd lcd=Nokia_3310_lcd();
  pinMode(3, OUTPUT);
  sensors.begin();
  // setup interrupt-driven keypad arrays
  // reset button arrays
  for(byte i=0; i<NUM_KEYS; i++){
    button_count[i]=0;
    button_status[i]=0;
    button_flag[i]=0;
  // Setup timer2 -- Prescaler/256
  TCCR2A &= ~((1<<WGM21) | (1<<WGM20));
  TCCR2B &= ~(1<<WGM22);
  TCCR2B = (1<<CS22)|(1<<CS21);
  ASSR |=(0<<AS2);
  // Use normal mode
  TCCR2A =0;
  //Timer2 Overflow Interrupt Enable
  TIMSK2 |= (0<<OCIE2A);
  TCNT2=0x6;  // counting starts from 6;
  TIMSK2 = (1<<TOIE2);
  SREG|=1<<SREG_I;
  lcd.init();
  lcd.clear();
  //menu initialization
  init_MENU();
  current_menu_item = 0;
/* loop */
  byte i;
  for(i=0; i<NUM_KEYS; i++) {
    if(button_flag[i] !=0) {
      button_flag[i]=0;  // reset button flag
      switch(i){
      case UP_KEY:
        // current item to normal display
        lcd.writeString(MENU_X, MENU_Y + current_menu_item, menu_items[current_menu_item], MENU_NORMAL );
        current_menu_item -=1;
        if(current_menu_item <0)  current_menu_item = NUM_MENU_ITEM -1;
        // next item to highlight display
        lcd.writeString(MENU_X, MENU_Y + current_menu_item, menu_items[current_menu_item], MENU_HIGHLIGHT );
      case DOWN_KEY:
        current_menu_item +=1;
        if(current_menu_item >(NUM_MENU_ITEM-1))  current_menu_item = 0;
      case LEFT_KEY:
        init_MENU();
      case RIGHT_KEY:
        lcd.clear();
        (*menu_funcs[current_menu_item])();
        lcd.clear();
        init_MENU();
/* menu functions */
void init_MENU(void) {
  byte i;
  lcd.clear();
  lcd.writeString(MENU_X, MENU_Y, menu_items[0], MENU_HIGHLIGHT );
  for (i=1; i<NUM_MENU_ITEM; i++) {
    lcd.writeString(MENU_X, MENU_Y+i, menu_items[i], MENU_NORMAL);
// waiting for center key press
void waitfor_OKkey() {
  byte i;
  byte key = 0xFF;
  while (key!= CENTER_KEY){
    for(i=0; i<NUM_KEYS; i++){
      if(button_flag[i] !=0){
        if(i== CENTER_KEY) key=CENTER_KEY;
// Check if joystick is moved or pressed
byte checkKeypressed() {
  byte key = 0xFF;
  for(int i=0; i<NUM_KEYS; i++){
  return key;
char numStr[8];
// Format a number to 2 decimal places
void formatNum( int num ) {
  // First part before decimalpoint
  itoa( num / 100, numStr, 10 );
  int pos = strlen( numStr );
  numStr[pos++] = '.';
  int decimal = num % 100;
  if( decimal > 9 ) {
    itoa( decimal, &numStr[pos], 10 );
    numStr[pos++] = '0';
// Display temperature in big digits, humidity in small digits underneath
void temperature() {
  int temp1, temp2, temp3, temp4, temp5;
  char temp[3];
  char* shower;
  // Display non changing text, there is a slight delay while first reading is taken
  lcd.writeString(0, 0, "Number", MENU_NORMAL);
  lcd.writeString(10, 1, "Of", MENU_NORMAL);
  lcd.writeString(0, 2, "Showers", MENU_NORMAL);
  lcd.writeString(0, 3, "avail:", MENU_NORMAL);
  lcd.writeString(75, 0, "C", MENU_NORMAL);
  lcd.writeString(75, 1, "C", MENU_NORMAL);
  lcd.writeString(75, 2, "C", MENU_NORMAL);
  lcd.writeString(75, 3, "C", MENU_NORMAL);
  lcd.writeString(75, 4, "C", MENU_NORMAL);
  lcd.writeString(38, 5, "OK", MENU_HIGHLIGHT );
  long lastUpdate = 0;  // Force update
  byte i;
  byte key = 0xFF;
  // Loop to display temperaure/humidity with check for key press to exit
  while (key!= CENTER_KEY) {
    // Update temp
    if( millis() > lastUpdate + 1000) {
      // Read temperature and humidity
      //Request and display temperatures
      sensors.requestTemperatures();
      temp1 = sensors.getTempCByIndex(0);
      temp2 = sensors.getTempCByIndex(1);
      temp3 = sensors.getTempCByIndex(2);
      temp4 = sensors.getTempCByIndex(3);
      temp5 = sensors.getTempCByIndex(4);
      itoa(temp1, temp, 10);
      lcd.writeString(60, 0, temp, MENU_NORMAL);
      itoa(temp2, temp, 10);
      lcd.writeString(60, 1, temp, MENU_NORMAL);
      itoa(temp3, temp, 10);
      lcd.writeString(60, 2, temp, MENU_NORMAL);
      itoa(temp4, temp, 10);
      lcd.writeString(60, 3, temp, MENU_NORMAL);
      itoa(temp5, temp, 10);
      lcd.writeString(60, 4, temp, MENU_NORMAL);
      if (temp1 >= 50 && temp4 >= 50)
      shower = "Bath";
      else if (temp1 >= 50 && temp2 >= 35 && temp3 <= 30)
      shower = "2";
      else if (temp1 >= 50 && temp2 >= 20)
      shower = "1";
      else if (temp1 <=45)
      shower = "0";
    lcd.writeString(10, 4, shower, MENU_NORMAL);
      lastUpdate = millis();
    key = checkKeypressed();
Part 2:
void waterreq()
void shower1()
    lcd.clear();
    init_MENU();
    while (shower < "1");
      digitalWrite (3, HIGH);
void shower15()
    lcd.clear();
    init_MENU();
    while (shower < "1.5");
void shower2()
    lcd.clear();
    init_MENU();
    while (shower < "2");
void shower25()
    lcd.clear();
    init_MENU();
    while (shower < "2.5");
void bath()
    lcd.clear();
    init_MENU();
    while (shower < "Bath");
void none()
    lcd.clear();
    init_MENU();
// The followinging are interrupt-driven keypad reading functions
//  which includes DEBOUNCE ON/OFF mechanism, and continuous pressing detection
// Convert ADC value to key number
char get_key(unsigned int input) {
  char k;
  for (k = 0; k < NUM_KEYS; k++) {
    if (input < adc_key_val[k]) {
      return k;
  if (k >= NUM_KEYS)
    k = -1;     // No valid key pressed
  return k;
void update_adc_key() {
  int adc_key_in;
  char key_in;
  byte i;
  adc_key_in = analogRead(0);
  key_in = get_key(adc_key_in);
    if(key_in==i) { //one key is pressed
      if(button_count[i]<DEBOUNCE_MAX)       {
        button_count[i]++;
        if(button_count[i]>DEBOUNCE_ON)         {
          if(button_status[i] == 0)           {
            button_flag[i] = 1;
            button_status[i] = 1; //button debounced to 'pressed' status
    } else  { // no button pressed
      if (button_count[i] >0) {
        button_flag[i] = 0;
        button_count[i]--;
        if(button_count[i]<DEBOUNCE_OFF) {
          button_status[i]=0;   //button debounced to 'released' status
 //Timer2 interrupt routine -
 //1/(160000000/256/(256-6)) = 4ms interval
ISR(TIMER2_OVF_vect) {
  TCNT2  = 6;
  update_adc_key();
I'm stumped on this, i was hoping someone could give some insight to the problem even if not directly familiar with the LCD or library itself
