NetBeans programming under C++
I use the netbeans plugin for programming the Intel Galileo but I would like to know how to configure the make file in such a case
as setting for example
COM_PORT = /dev/ttyACM0
BAUD_RATE = 115200
ARDUINO_VERSION = 163
ARDUINO_BASE_DIR =/usr/share/arduino/
ARDUINO_CORE_DIR = {ARDUINO_BASE_DIR}/hardware/arduino/cores/arduino ARDUINO_LIB_DIR = {ARDUINO_BASE_DIR}/libraries
Arduino Uno:
ARDUINO_MODEL = atmega328p
ARDUINO_PROGRAMMER = arduino
ARDUINO_PINS_DIR = ${ARDUINO_BASE_DIR}/hardware/arduino/variants/standard
for arduino uno what should be the parameter ARDUINO_MODEL in the case of galileo ?
in the same time I get a not found library arduinolibs missing why?
and finally for KUBUNTU 14.19 I can install arduino using the synaptic package
where the software is implemented in /usr/share/arduino
how to upgrade to arduino 1.6.3?
thank you
main.cpp (359 Bytes)
fred2009: and finally for KUBUNTU 14.19 I can install arduino using the synaptic package where the software is implemented in /usr/share/arduino how to upgrade to arduino 1.6.3?
The Arduino IDE is just a Java program. All you need to do is download and save it somewhere. You can have several version on your PC at the same time. (I presume you already have Java on your PC).
...R
