I'm essentially trying to make a project with a built in, two port network switch. Getting a network signal over ethernet is simple enough, but how can I pass that through? Obviously can't stack two ethernet shields. I could use different pins though couldn't I? I have a bunch of pro-mini's to play around with and a big breadboard. Would I need two W5100's?
Elusid:
Nothing obvious about that, and you probably could. I think it is just a matter of clipping out snd re-routing the CS pin on one, and calling it something else. Your real problems are somewhere else.
Could anyone point me in the right direction to getting two of these hooked up to an ATmega328 based board? I'm using Pro-Mini's. I'm trying to make many devices that can daisy-chain together. Basically I need it to be a two port network switch.
