network programming
hello every body
i am recently working over a mobile robot project. here i need to send an instruction to arduino microcontroller over network. for this i had choosed client server architecture. i modified the server program to read the buffer to device file descriptor ("/dev/ttyACM0" in this case.
i was able to compile the programs and run them. when i send a request from client to server . the server simply closes with out receiving the message.
The led is blinking in this case once
my working environment is
Linux 10.10
in order to execute the client
$ ./client
for serial_server
$ ./serial_server
below is the code of the programs
client code
Code:
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <string.h>
#include <sys/types.h>
#include <sys/socket.h>
#include <netinet/in.h>
#include <netdb.h>
void error(const char *msg)
    perror(msg);
    exit(0);
int main(int argc, char *argv[])
    int sockfd, portno, n;
    struct sockaddr_in serv_addr;
    struct hostent *server;
    char buffer[256];
    if (argc < 3) {
       fprintf(stderr,"usage %s hostname port\n", argv[0]);
       exit(0);
    portno = atoi(argv[2]);
    sockfd = socket(AF_INET, SOCK_STREAM, 0);
    if (sockfd < 0)
        error("ERROR opening socket");
    server = gethostbyname(argv[1]);
    if (server == NULL) {
        fprintf(stderr,"ERROR, no such host\n");
        exit(0);
    bzero((char *) &serv_addr, sizeof(serv_addr));
    serv_addr.sin_family = AF_INET;
    bcopy((char *)server->h_addr,
         (char *)&serv_addr.sin_addr.s_addr,
         server->h_length);
    serv_addr.sin_port = htons(portno);
    if (connect(sockfd,(struct sockaddr *) &serv_addr,sizeof(serv_addr)) < 0)
        error("ERROR connecting");
    printf("Please enter the message: ");
    bzero(buffer,256);
    fgets(buffer,255,stdin);
    n = write(sockfd,buffer,strlen(buffer));
    if (n < 0)
         error("ERROR writing to socket");
    bzero(buffer,256);
    n = read(sockfd,buffer,255);
    if (n < 0)
         error("ERROR reading from socket");
    printf("%s\n",buffer);
    close(sockfd);
    return 0;
serial_server code
/* A simple server in the internet domain using TCP
   The port number is passed as an argument */
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <unistd.h>
#include<errno.h>
#include<sys/ioctl.h>
#include<termios.h>
#include<fcntl.h>
#include<getopt.h>
    perror(msg);
    exit(1);
     int sockfd, newsockfd, portno;
     socklen_t clilen;
     char buffer[256];
     struct sockaddr_in serv_addr, cli_addr;
     int n,k;
// serial data
     int fd;
     int baudrate = B9600;
     int rc;
     if (argc < 2) {
         fprintf(stderr,"ERROR, no port provided\n");
         exit(1);
     if (sockfd < 0)
     portno = atoi(argv[1]);
     serv_addr.sin_addr.s_addr = INADDR_ANY;
     if (bind(sockfd, (struct sockaddr *) &serv_addr,
              error("ERROR on binding");
     listen(sockfd,5);
     clilen = sizeof(cli_addr);
     newsockfd = accept(sockfd,
                 (struct sockaddr *) &cli_addr,
                 &clilen);
     if (newsockfd < 0)
          error("ERROR on accept");
     bzero(buffer,256);
 // serial filedescriptor initializing ;
      fd = open("/dev/ttyACM0", O_RDWR | O_NOCTTY | O_NDELAY);
    if (fd == -1)  {
        perror("init_serialport: Unable to open port ");
        return -1;
     n = read(newsockfd,buffer,255);
     if (n < 0) error("ERROR reading from socket");
    k= write(fd,buffer,255);
    if(k<0)error("Unable to open the arduino ");
     printf("Here is the message: %s\n",buffer);
     n = write(newsockfd,"I got your message",18);
     if (n < 0) error("ERROR writing to socket");
    if(k<0)error("Unable to send to the arduino ");
     close(newsockfd);
     close(sockfd);
     return 0;
sketch of arduino
void setup()   {
 pinMode(9, OUTPUT);
 digitalWrite(9,HIGH);
 digitalWrite(9,LOW);
  pinMode(11,OUTPUT);
  digitalWrite(11,HIGH);
 digitalWrite(11,LOW);
 int incomingByte = 0;
   // send data only when you receive data:
	if (Serial.available() > 0) {
                char text = Serial.read();
                Serial.println(text);
                switch(text)
                  case 'a':
                   case 'b':
Opening a serial port resets the Arduino. In addition to the normal start up time, you are farting around in setup blinking LEDs for a full second.
During that time, your server has send a response, expected a reply, gotten nothing, and quit.
The description of your network is vague. If you are sending info from your pc to the arduino, and the application on the pc opens/closes the serial port each time data is sent, you will need to defeat the arduino auto reset by using a 100 ohm resistor between the arduino +5v and reset pins, or use a large capacitor between the reset pin and ground.
