Hallo ich habe ein Problem
ich bin neu in der Materie
ich habe mir dieses set Gekauft SainSmart UNO+2004 LCD+Sensor Shield V4 und wollte es für LCDSmartie nutzen aber bekomme es nicht richtig zum laufen .
Kann mir einer Helfen??
ich habe es mit diesem Code Versucht??
#include <Wire.h>
LiquidCrystal_I2C lcd(0x3F,20,4); // set the LCD address to 0x27 for a 16 chars and 2 line display
//Serial.begin(19200);
lcd.init(); // initialize the lcd
lcd.init();
lcd.begin(20, 4);
lcd.backlight();
lcd.clear();
lcd.print("** LCD Smartie **");
lcd.setCursor(0,1);
lcd.print("** on Arduino **");
lcd.setCursor(0,2);
lcd.print("** by techroll **");
lcd.setCursor(0,3);
lcd.print("** techroll.de **");
byte serial_getch() {
int incoming;
while (Serial.available()==0) {
// read the incoming byte:
incoming = Serial.read();
return (byte) (incoming &0xff);
byte rxbyte;
byte temp;
byte col;
byte row;
uint8_t location;
uint8_t charMap[7];
rxbyte = serial_getch();
if (rxbyte == 254) //Matrix Orbital uses 254 prefix for commands
switch (serial_getch())
case 66: //backlight on (at previously set brightness)
// not implemented
case 70: //backlight off
// not implemented
case 71: //set cursor position
col = (serial_getch() - 1); //get column byte
row = (serial_getch());
switch (serial_getch()) //get row byte
//line 1 is already set up
case 2:
temp += 0x40;
case 3:
temp += 0x14;
case 4:
temp += 0x54;
default:
//lcd.commandWrite(0b10000000 + temp);
lcd.setCursor(col,row-1);
case 72: //cursor home (reset display position)
//lcd.commandWrite(2);
lcd.setCursor(0,0);
case 74: //show underline cursor
//lcd.commandWrite(0b00001110);
case 75: //underline cursor off
case 84: //block cursor off
//lcd.commandWrite(0b00001100);
case 76: //move cursor left
//lcd.commandWrite(16);
case 77: //move cursor right
//lcd.commandWrite(20);
case 78: //define custom char
//location = 64+serial_getch()*8;
location = serial_getch();
for (temp = 0; temp < 8; temp++)
charMap[temp] = serial_getch(); //get each pattern byte
lcd.createChar(location, charMap);
case 83: //show blinking block cursor
//lcd.commandWrite(0b00001111);
case 86: //GPO OFF
//implement later
case 87: //GPO ON
/*temp = serial_getch();
if (temp == 1)
GPO1 = GPO_ON;
case 88: //clear display, cursor home
//lcd.commandWrite(1);
lcd.clear();
lcd.setCursor(0,0);
case 152: //set and remember (doesn't save value, though)
case 153: //set backlight brightness
//not implemented
//these commands ignored (no parameters)
case 35: //read serial number
case 36: //read version number
case 55: //read module type
case 59: //exit flow-control mode
case 65: //auto transmit keypresses
case 96: //auto-repeat mode off (keypad)
case 67: //auto line-wrap on
case 68: //auto line-wrap off
case 81: //auto scroll on
case 82: //auto scroll off
case 104: //init horiz bar graph
case 109: //init med size digits
case 115: //init narrow vert bar graph
case 118: //init wide vert bar graph
default:
//all other commands ignored and parameter byte discarded
temp = serial_getch(); //dump the command code
return;
} //END OF COMMAND HANDLER
//change accented char to plain, detect and change descenders
//NB descenders only work on 5x10 displays. This lookup table works
// with my DEM-20845 (Display Elektronik GmbH) LCD using KS0066 chip.
switch (rxbyte)
//chars that have direct equivalent in LCD charmap
/* case 0x67: //g
rxbyte = 0xE7;
case 0x6A: //j
rxbyte = 0xEA;
case 0x70: //p
rxbyte = 0xF0;
case 0x71: //q
rxbyte = 0xF1;
case 0x79: //y
rxbyte = 0xF9;
*/ case 0xE4: //ASCII "a" umlaut
rxbyte = 0xE1;
case 0xF1: //ASCII "n" tilde
rxbyte = 0xEE;
case 0xF6: //ASCII "o" umlaut
rxbyte = 0xEF; //was wrong in v0.86
case 0xFC: //ASCII "u" umlaut
rxbyte = 0xF5;
//accented -> plain equivalent
//and misc symbol translation
case 0xA3: //sterling (pounds)
rxbyte = 0xED;
/* case 0xB0: //degrees symbol
rxbyte = 0xDF;
*/ case 0xB5: //mu
rxbyte = 0xE4;
case 0xC0: //"A" variants
case 0xC1:
case 0xC2:
case 0xC3:
case 0xC4:
case 0xC5:
rxbyte = 0x41;
case 0xC8: //"E" variants
case 0xC9:
case 0xCA:
case 0xCB:
rxbyte = 0x45;
case 0xCC: //"I" variants
case 0xCD:
case 0xCE:
case 0xCF:
rxbyte = 0x49;
case 0xD1: //"N" tilde -> plain "N"
rxbyte = 0x43;
case 0xD2: //"O" variants
case 0xD3:
case 0xD4:
case 0xD5:
case 0xD6:
case 0xD8:
rxbyte = 0x4F;
case 0xD9: //"U" variants
case 0xDA:
case 0xDB:
case 0xDC:
rxbyte = 0x55;
case 0xDD: //"Y" acute -> "Y"
rxbyte = 0x59;
/* case 0xDF: //beta //mucks up LCDSmartie's degree symbol??
rxbyte = 0xE2;
*/ case 0xE0: //"a" variants except umlaut
case 0xE1:
case 0xE2:
case 0xE3:
case 0xE5:
rxbyte = 0x61;
case 0xE7: //"c" cedilla -> "c"
rxbyte = 0x63;
case 0xE8: //"e" variants
case 0xE9:
case 0xEA:
case 0xEB:
rxbyte = 0x65;
case 0xEC: //"i" variants
case 0xED:
case 0xEE:
case 0xEF:
rxbyte = 0x69;
case 0xF2: //"o" variants except umlaut
case 0xF3:
case 0xF4:
case 0xF5:
case 0xF8:
rxbyte = 0x6F;
case 0xF7: //division symbol
rxbyte = 0xFD;
case 0xF9: //"u" variants except umlaut
case 0xFA:
case 0xFB:
rxbyte = 0x75;
default:
lcd.print(rxbyte); //otherwise a plain char so we print it to lcd
return;
da es der für LCDSmartie ist .
Nur am Display ist die I2c Platiene angelötet deswegen wird der Code warscheinlich nicht richtig gehen was muss ich Ändern im Code???
wenn ich LCD smarty Starte zeigt er mir lauter zahlen an und das wars sobald ich es Schließe steht wieder der Standat text im Display.
