hi everybody
how are you guys.hope yall are safe.
lately whatever projects im doing with my lcd shows
no matching function for call to 'LiquidCrystal_I2C::begin()'
here is the code i used -
#include <Wire.h>
#include <RTClib.h>
LiquidCrystal_I2C lcd(0x3F,16,2); // Display I2C 16 x 2
RTC_DS1307 RTC;
//************Button*****************//
int P1=6; // Button SET MENU'
int P2=7; // Button +
int P3=8; // Button -
//************Variables**************//
int hourupg;
int minupg;
int yearupg;
int monthupg;
int dayupg;
int menu =0;
lcd.begin();
lcd.backlight();
lcd.clear();
pinMode(P1,INPUT);
pinMode(P2,INPUT);
pinMode(P3,INPUT);
Wire.begin();
RTC.begin();
if (! RTC.isrunning()) {
Serial.println("RTC is NOT running!");
// Set the date and time at compile time
RTC.adjust(DateTime(__DATE__, __TIME__));
// RTC.adjust(DateTime(__DATE__, __TIME__)); //removing "//" to adjust the time
// The default display shows the date and time
int menu=0;
// check if you press the SET button and increase the menu index
if(digitalRead(P1))
menu=menu+1;
// in which subroutine should we go?
if (menu==0)
DisplayDateTime(); // void DisplayDateTime
if (menu==1)
DisplaySetHour();
if (menu==2)
DisplaySetMinute();
if (menu==3)
DisplaySetYear();
if (menu==4)
DisplaySetMonth();
if (menu==5)
DisplaySetDay();
if (menu==6)
StoreAgg();
menu=0;
delay(100);
void DisplayDateTime ()
// We show the current date and time
DateTime now = RTC.now();
lcd.setCursor(0, 1);
lcd.print("Hour:");
if (now.hour()<=9)
lcd.print("0");
lcd.print(now.hour(), DEC);
hourupg=now.hour();
lcd.print(":");
if (now.minute()<=9)
lcd.print("0");
lcd.print(now.minute(), DEC);
minupg=now.minute();
lcd.print(":");
if (now.second()<=9)
lcd.print("0");
lcd.print(now.second(), DEC);
lcd.setCursor(0, 0);
lcd.print("Date: ");
if (now.day()<=9)
lcd.print("0");
lcd.print(now.day(), DEC);
dayupg=now.day();
lcd.print("/");
if (now.month()<=9)
lcd.print("0");
lcd.print(now.month(), DEC);
monthupg=now.month();
lcd.print("/");
lcd.print(now.year(), DEC);
yearupg=now.year();
void DisplaySetHour()
// time setting
lcd.clear();
if(digitalRead(P2)==HIGH)
if(hourupg==23)
hourupg=0;
hourupg=hourupg+1;
if(digitalRead(P3)==HIGH)
if(hourupg==0)
hourupg=23;
hourupg=hourupg-1;
lcd.setCursor(0,0);
lcd.print("Set time:");
lcd.setCursor(0,1);
lcd.print(hourupg,DEC);
delay(200);
void DisplaySetMinute()
// Setting the minutes
lcd.clear();
if (minupg==59)
minupg=0;
minupg=minupg+1;
if (minupg==0)
minupg=59;
minupg=minupg-1;
lcd.setCursor(0,0);
lcd.print("Set Minutes:");
lcd.setCursor(0,1);
lcd.print(minupg,DEC);
delay(200);
void DisplaySetYear()
// setting the year
lcd.clear();
yearupg=yearupg+1;
yearupg=yearupg-1;
lcd.setCursor(0,0);
lcd.print("Set Year:");
lcd.setCursor(0,1);
lcd.print(yearupg,DEC);
delay(200);
void DisplaySetMonth()
// Setting the month
lcd.clear();
if (monthupg==12)
monthupg=1;
monthupg=monthupg+1;
if (monthupg==1)
monthupg=12;
monthupg=monthupg-1;
lcd.setCursor(0,0);
lcd.print("Set Month:");
lcd.setCursor(0,1);
lcd.print(monthupg,DEC);
delay(200);
void DisplaySetDay()
// Setting the day
lcd.clear();
if (dayupg==31)
dayupg=1;
dayupg=dayupg+1;
if (dayupg==1)
dayupg=31;
dayupg=dayupg-1;
lcd.setCursor(0,0);
lcd.print("Set Day:");
lcd.setCursor(0,1);
lcd.print(dayupg,DEC);
delay(200);
void StoreAgg()
// Variable saving
lcd.clear();
lcd.setCursor(0,0);
lcd.print("SAVING IN");
lcd.setCursor(0,1);
lcd.print("PROGRESS");
RTC.adjust(DateTime(yearupg,monthupg,dayupg,hourupg,minupg,0));
delay(200);
here is my error
Arduino: 1.8.13 (Windows 10), Board: "Arduino Uno"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Manjuiniyan\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Manjuiniyan\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Manjuiniyan\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=2341_0043 -ide-version=10813 -build-path C:\Users\MANJUI~1\AppData\Local\Temp\arduino_build_5300 -warnings=none -build-cache C:\Users\MANJUI~1\AppData\Local\Temp\arduino_cache_837552 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Users\Manjuiniyan\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\Manjuiniyan\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.arduinoOTA.path=C:\Users\Manjuiniyan\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\Manjuiniyan\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.avr-gcc.path=C:\Users\Manjuiniyan\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\Manjuiniyan\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -verbose C:\Users\Manjuiniyan\Documents\Arduino\arduino_rtc_date_set_time\arduino_rtc_date_set_time.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Manjuiniyan\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Manjuiniyan\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Manjuiniyan\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=2341_0043 -ide-version=10813 -build-path C:\Users\MANJUI~1\AppData\Local\Temp\arduino_build_5300 -warnings=none -build-cache C:\Users\MANJUI~1\AppData\Local\Temp\arduino_cache_837552 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=C:\Users\Manjuiniyan\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\Manjuiniyan\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.arduinoOTA.path=C:\Users\Manjuiniyan\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\Manjuiniyan\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.avr-gcc.path=C:\Users\Manjuiniyan\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\Manjuiniyan\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -verbose C:\Users\Manjuiniyan\Documents\Arduino\arduino_rtc_date_set_time\arduino_rtc_date_set_time.ino
Using board 'uno' from platform in folder: C:\Users\Manjuiniyan\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3
Using core 'arduino' from platform in folder: C:\Users\Manjuiniyan\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3
Detecting libraries used...
"C:\Users\Manjuiniyan\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\Manjuiniyan\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\cores\arduino" "-IC:\Users\Manjuiniyan\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\variants\standard" "C:\Users\MANJUI~1\AppData\Local\Temp\arduino_build_5300\sketch\arduino_rtc_date_set_time.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for Wire.h: [Wire@1.0]
ResolveLibrary(Wire.h)
-> candidates: [Wire@1.0]
"C:\Users\Manjuiniyan\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\Manjuiniyan\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\cores\arduino" "-IC:\Users\Manjuiniyan\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\variants\standard" "-IC:\Users\Manjuiniyan\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\libraries\Wire\src" "C:\Users\MANJUI~1\AppData\Local\Temp\arduino_build_5300\sketch\arduino_rtc_date_set_time.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for RTClib.h: [RTClib-master@1.12.4]
ResolveLibrary(RTClib.h)
-> candidates: [RTClib-master@1.12.4]
"C:\Users\Manjuiniyan\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\Manjuiniyan\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\cores\arduino" "-IC:\Users\Manjuiniyan\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\variants\standard" "-IC:\Users\Manjuiniyan\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\libraries\Wire\src" "-IC:\Users\Manjuiniyan\Documents\Arduino\libraries\RTClib-master" "C:\Users\MANJUI~1\AppData\Local\Temp\arduino_build_5300\sketch\arduino_rtc_date_set_time.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for LiquidCrystal_I2C.h: [LiquidCrystal_I2C@1.1.1]
ResolveLibrary(LiquidCrystal_I2C.h)
-> candidates: [LiquidCrystal_I2C@1.1.1]
"C:\Users\Manjuiniyan\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\Manjuiniyan\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\cores\arduino" "-IC:\Users\Manjuiniyan\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\variants\standard" "-IC:\Users\Manjuiniyan\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\libraries\Wire\src" "-IC:\Users\Manjuiniyan\Documents\Arduino\libraries\RTClib-master" "-IC:\Users\Manjuiniyan\Documents\Arduino\libraries\LiquidCrystal_I2C" "C:\Users\MANJUI~1\AppData\Local\Temp\arduino_build_5300\sketch\arduino_rtc_date_set_time.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\Users\Manjuiniyan\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\Manjuiniyan\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\cores\arduino" "-IC:\Users\Manjuiniyan\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\variants\standard" "-IC:\Users\Manjuiniyan\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\libraries\Wire\src" "-IC:\Users\Manjuiniyan\Documents\Arduino\libraries\RTClib-master" "-IC:\Users\Manjuiniyan\Documents\Arduino\libraries\LiquidCrystal_I2C" "C:\Users\Manjuiniyan\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\libraries\Wire\src\Wire.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\Users\Manjuiniyan\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\Manjuiniyan\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\cores\arduino" "-IC:\Users\Manjuiniyan\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\variants\standard" "-IC:\Users\Manjuiniyan\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\libraries\Wire\src" "-IC:\Users\Manjuiniyan\Documents\Arduino\libraries\RTClib-master" "-IC:\Users\Manjuiniyan\Documents\Arduino\libraries\LiquidCrystal_I2C" "C:\Users\Manjuiniyan\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\libraries\Wire\src\utility\twi.c" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\Users\Manjuiniyan\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\Manjuiniyan\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\cores\arduino" "-IC:\Users\Manjuiniyan\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\variants\standard" "-IC:\Users\Manjuiniyan\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\libraries\Wire\src" "-IC:\Users\Manjuiniyan\Documents\Arduino\libraries\RTClib-master" "-IC:\Users\Manjuiniyan\Documents\Arduino\libraries\LiquidCrystal_I2C" "C:\Users\Manjuiniyan\Documents\Arduino\libraries\RTClib-master\RTClib.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
"C:\Users\Manjuiniyan\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\Manjuiniyan\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\cores\arduino" "-IC:\Users\Manjuiniyan\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\variants\standard" "-IC:\Users\Manjuiniyan\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\libraries\Wire\src" "-IC:\Users\Manjuiniyan\Documents\Arduino\libraries\RTClib-master" "-IC:\Users\Manjuiniyan\Documents\Arduino\libraries\LiquidCrystal_I2C" "C:\Users\Manjuiniyan\Documents\Arduino\libraries\LiquidCrystal_I2C\LiquidCrystal_I2C.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Generating function prototypes...
"C:\Users\Manjuiniyan\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\Manjuiniyan\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\cores\arduino" "-IC:\Users\Manjuiniyan\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\variants\standard" "-IC:\Users\Manjuiniyan\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\libraries\Wire\src" "-IC:\Users\Manjuiniyan\Documents\Arduino\libraries\RTClib-master" "-IC:\Users\Manjuiniyan\Documents\Arduino\libraries\LiquidCrystal_I2C" "C:\Users\MANJUI~1\AppData\Local\Temp\arduino_build_5300\sketch\arduino_rtc_date_set_time.ino.cpp" -o "C:\Users\MANJUI~1\AppData\Local\Temp\arduino_build_5300\preproc\ctags_target_for_gcc_minus_e.cpp" -DARDUINO_LIB_DISCOVERY_PHASE
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\MANJUI~1\AppData\Local\Temp\arduino_build_5300\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Users\Manjuiniyan\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\Manjuiniyan\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\cores\arduino" "-IC:\Users\Manjuiniyan\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\variants\standard" "-IC:\Users\Manjuiniyan\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\libraries\Wire\src" "-IC:\Users\Manjuiniyan\Documents\Arduino\libraries\RTClib-master" "-IC:\Users\Manjuiniyan\Documents\Arduino\libraries\LiquidCrystal_I2C" "C:\Users\MANJUI~1\AppData\Local\Temp\arduino_build_5300\sketch\arduino_rtc_date_set_time.ino.cpp" -o "C:\Users\MANJUI~1\AppData\Local\Temp\arduino_build_5300\sketch\arduino_rtc_date_set_time.ino.cpp.o"
C:\Users\Manjuiniyan\Documents\Arduino\arduino_rtc_date_set_time\arduino_rtc_date_set_time.ino: In function 'void setup()':
arduino_rtc_date_set_time:25:13: error: no matching function for call to 'LiquidCrystal_I2C::begin()'
lcd.begin();
In file included from C:\Users\Manjuiniyan\Documents\Arduino\arduino_rtc_date_set_time\arduino_rtc_date_set_time.ino:3:0:
C:\Users\Manjuiniyan\Documents\Arduino\libraries\LiquidCrystal_I2C/LiquidCrystal_I2C.h:58:8: note: candidate: void LiquidCrystal_I2C::begin(uint8_t, uint8_t, uint8_t)
void begin(uint8_t cols, uint8_t rows, uint8_t charsize = LCD_5x8DOTS );
C:\Users\Manjuiniyan\Documents\Arduino\libraries\LiquidCrystal_I2C/LiquidCrystal_I2C.h:58:8: note: candidate expects 3 arguments, 0 provided
Using library Wire at version 1.0 in folder: C:\Users\Manjuiniyan\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.3\libraries\Wire
Using library RTClib-master at version 1.12.4 in folder: C:\Users\Manjuiniyan\Documents\Arduino\libraries\RTClib-master
Using library LiquidCrystal_I2C at version 1.1.1 in folder: C:\Users\Manjuiniyan\Documents\Arduino\libraries\LiquidCrystal_I2C
exit status 1
please help me to fix this error
here is the link https://create.arduino.cc/projecthub/tittiamo68/clock-set-date-time-0d46a4
