New and delete operator with queues
Im trying to write my own code for a queue and will be using the new and delete commands but i want to be sure this code wont have memory leaks or other problems.
Its a simple class for queues and the size of the queue is known at compile time, so this shouldnt be a problem.
Its my first time using new, delete and templates, so suggestions would be greatly helpful.
template <typename T>
class Queue {
public:
	Queue(uint16_t size);
	~Queue();
	T deQueue();
	bool enQueue(T in);
	bool isEmpty() { return numElements == 0 ? true : false; };
	bool isFull() { return numElements == size ? true : false; };
	T rear() { return queue[head == 0 ? (size - 1) : (head - 1)]; };
	T front() { return queue[tail]; };
private:
	T *queue;
	uint16_t head = 0;
	uint16_t tail = 0;
	uint16_t size;
	uint16_t numElements = 0;
Queue<T>::Queue(uint16_t _size) {
	size = _size;
	queue = new T[size];
Queue<T>::~Queue() {
	delete [] queue;
T Queue<T>::deQueue() {
	T obj = NULL;
	if (numElements == 0) return obj;
	obj = queue[tail];
	tail++;
	numElements--;
	if (tail >= size) tail = 0;
	return obj;
bool Queue<T>::enQueue(T in) {
	if (numElements == size) return false;
	queue[head] = in;
	head++;
	numElements++;
	if (head == size) head = 0;
	return true;
Is this an academic exercise? I'm pretty sure the STL has queues.
What Arduino are you using?
If it is an Uno or Mega (or similar) I suggest you allocate the memory needed for the biggest queue(s) at compile time as memory manipulation in the small memory of an Arduino can easily result in a crash.
You would have more room for manoeuvre in an ESP8266 or ESP32 but even then I would be wary of the possibilities of writing on memory you don't own when there is no operating system to protect you.
...R
What is "the STL"?
-jim lee
C++ Standard Template Library
Since your Queue class contains a pointer to a dynamically allocated array of objects, you should probably either delete 'copy constructor' and '&operator=' functionality or properly implement them. Otherwise, the default implementation of these operations will simply copy the pointer, thus leaving you with multiple objects pointing to the same dynamically allocated array.
