Hi everyone. I am very new to this and need coding help. Here is what I would like my project to do.
I am making a Cornhole board. When a bag goes through the hole, I want it to break the IR beam, and flash one LED for 3 seconds then turn off and be ready for the next input.
I’m sure this is simple, but like I said I am very new to coding here. Any help would be greatly appreciated!! I have all the parts, just need the code.
Thanks so much!
// Define pins for LED
int redLED = 13;
// Input from Motion Sensor
int pirPin = 7;
// Variable for Motion Detected
int motionDetected = 0;
// Variable to store value from PIR
int pirValue;
// Variable for counter
int counter = 0;
// Setup LEDs as Outputs
pinMode(redLED, OUTPUT);
// Setup PIR as Input
pinMode(pirPin, INPUT);
// Get value from motion sensor
pirValue = digitalRead(pirPin);
// See if motion Detected
if (pirValue == 1){
// Display Triggered LED 10 times
for (counter = 0; counter < 10; ++counter)
digitalWrite(redLED, HIGH);
motionDetected = 1;
delay(200);
digitalWrite(redLED, LOW);
delay(200);
So far, this is what I came up with. Can anyone tell me if this looks correct?? I want the motion sensor to trip the LED and flash 10 times, then reset. I feel like I have the code for the "count" incorrectly added.
THANKS!
You're missing some braces in your for loop. I expect this was what you intended:
motionDetected = 1;
delay(200);
delay(200);
That motionDetected variable isn't doing anything for you (yet?).
int detectedLED = 13;
int counter = 0;
int pirPin = 7;
int pirValue;
// initialize digital pin LED_BUILTIN as an output.
pinMode(detectedLED, OUTPUT);
// the loop function runs over and over again forever
if (pirValue == 0)
for (counter = 0; counter < 5; ++counter)
digitalWrite(detectedLED, HIGH);
motionDetected = 0;
delay(30);
digitalWrite(detectedLED, LOW);
delay(30);
delay(30);
delay(30);
delay(30);
delay(30);
delay(30);
delay(100);
delay(30);
}else{
motionDetected == 1;
WildBill, thanks a ton! Worked with a few tweaks and I am running as hoped! This is my first project and I am excited to work on more! Figured I would share the code that worked for me. Ultimately, I wanted the LED to flash like a strobe 5 times.
