Hello,
I am currently dealing with the "web editor won't verify" issue that I've seen some other people talk about. I am having the issue with the new and old web editors, which I haven't seen before. The error message said to report the problem here, so here I am! Any help would be appreciated.
Thanks!
Edit: It seems other special characters are affected as well, such as an underscore in my case.
Hi @progmetalislife. I'm sorry about the problem you experienced with **Arduino Cloud*8.
Let's focus our attention on the "new" editor for now.
I'm going to ask you to attempt a very simple compilation using the "new" Cloud Editor in order to allow us to better understand the nature of the problem.
If your Arduino Cloud account is currently configured to use the "old" editor, click the following link to open the editor and then click the "New Cloud Editor is out, try it now!" link in the notification at the bottom right corner of the page to switch back to the "new" editor: https://create.arduino.cc/editor
Hey there!! Not sure if you solved this yet or not, but I was having the EXACT same issue and may have found a solution!! For me, my new file was NOT verifying on the new OR the old editor. Old files that I've had on this account for years WERE working so I tried to compare my code and see if I was messing anything up.
The only difference I found? The name of the file.
Your file name cannot have any spaces!!! Once I removed all of the spaces from my new file name, it started compiling!!
Thanks for sharing your solution @nory! The Arduino Cloud developers are aware of this bug (Cloud Editor allowing the creation of sketches with spaces in their names) and work is in progress to fix it.
