Hello Jon
I'm bumping this old thread
First, thanks for your menu class, this is exactly what I needed for my project.
I'm actually building an antenna tracker to track my drones using telemetry data.
Code is here: Google Code Archive - Long-term storage for Google Code Project Hosting.
On the ground device, there's an LCD ( i2c lcd03) proposing at startup a menu.
Here is the menu:
Menu Root:
- START
- SET_HOME
- CONFIGURATION:
- SERVOS:
- PAN:
- MIN_PWM
- MIN_ANGLE
- MAX_PWM
- MAX_ANGLE
- TILT:
- MIN_PWM
- MIN_ANGLE
- MAX_PWM
- MAX_ANGLE
- TEST
- BAUDRATE
Here is my init menu function:
void init_menu() {
rootMenu.add_item(&m1i1Item, &screen_tracking); //start track
rootMenu.add_item(&m1i2Item, &screen_sethome); //set home position
rootMenu.add_menu(&m1m3Menu); //configure
m1m3Menu.add_menu(&m1m3m1Menu); //config servos
m1m3m1Menu.add_menu(&m1m3m1m1Menu); //config pan
m1m3m1m1Menu.add_item(&m1m3m1m1l1Item, &configure_pan_minpwm); // pan min pwm
m1m3m1m1Menu.add_item(&m1m3m1m1l2Item, &configure_pan_minangle); // pan min angle
m1m3m1m1Menu.add_item(&m1m3m1m1l3Item, &configure_pan_maxpwm); // pan max pwm
m1m3m1m1Menu.add_item(&m1m3m1m1l4Item, &configure_pan_maxangle); // pan max angle
m1m3m1Menu.add_menu(&m1m3m1m2Menu); //config tilt
m1m3m1m2Menu.add_item(&m1m3m1m2l1Item, &configure_tilt_minpwm); // tilt min pwm
m1m3m1m2Menu.add_item(&m1m3m1m2l2Item, &configure_tilt_minangle); // tilt min angle
m1m3m1m2Menu.add_item(&m1m3m1m2l3Item, &configure_tilt_maxpwm); // tilt max pwm
m1m3m1m2Menu.add_item(&m1m3m1m2l4Item, &configure_tilt_maxangle); // tilt max angle
m1m3m1Menu.add_item(&m1m3m1i3Item, &configure_test_servo);
m1m3Menu.add_item(&m1m3l2Item, &configure_baudrate); //config baudrate
displaymenu.set_root_menu(&rootMenu);
Then in the mainloop, when current_activity == "MENU" , it calls at 10hz:
void display_menu() {
Menu const* displaymenu_current = displaymenu.get_current_menu();
//Serial.print("current menu = ");
//Serial.println(displaymenu_current->get_cur_menu_component_num());
MenuComponent const* displaymenu_sel = displaymenu_current->get_selected();
for (int n = 1; n < 5; ++n) {
char string_buffer[21];
if ( (displaymenu_current->get_num_menu_components()) >= n ) {
MenuComponent const* displaymenu_comp = displaymenu_current->get_menu_component(n-1);
String getname = displaymenu_comp->get_name();
for ( int l = getname.length()-1 ; l<20 ; l++ ) {
getname = getname + " ";
if (displaymenu_sel == displaymenu_comp) {
getname.setCharAt(19,'<');
getname.setCharAt(19, ' ');
getname.toCharArray(string_buffer,21);
else {
empty_line.toCharArray(string_buffer,21);
store_lcdline(n, string_buffer);
Then LCD screen is refreshed at 10hz on another timed loop in the main loop.
This works almost well.
When I stay inside the menu, I can go next, prev, back and select...
I use click button to select, & long_press button to go back to the parent.
The problem is when I select an item in a submenu. Imagine I've selected CONFIGURATION/TILT/MIN_PWM. My current_activity change from #MENU" to "TILT_MINPWM". ( so the display_menu function is not called anymore. )
It then call another function to display the configuration screen on the LCD & handle configuring parameters.
When I quit this screen, I change the current_status to "MENU", so it displays the menu again.
The problem is it doesn't go back to the previous menu state, it just start from the Root Menu, with the CONFIGURATION already selected.
I'd like to have it going back in menu_root/CONFIGURATION/SERVOS/TILT menu and not Root.
There's probably a mistake I've made somewhere, but I can't find it for now.
If you have a genius idea, I take it
Cheers.
