New Arduino Motor Shield R3
Hello to all i just buy a new Arduino Motor Shield R3 From Radio Shack http://arduino.cc/en/Main/ArduinoMotorShieldR3 and i found problems to run a simple step motor ( 4 wires) i can not get to turn the step motor i can not find any sketch or library for this new board i replace the values to work with pin 3 , 11 ,12 and 13 and still dont work
Please help me where i can get info, sketch or pde files
Thank
You replaced the values in what?
Fire up the IDE and start typing. When your done, post your code, if you have problems.
This is the code to be more speciffic
#include <Stepper.h>
/* This Rugged Motor Shield application demonstrates keyboard control
  • of a stepper motor. Assumptions:
    • stepper motor connected to the 2 phases
    • 8V-30V supply connected to Vin (optional, else Arduino Vin is used)
    • Vin jumper is cut (J21) (only required if Vin>15V)
    • FAULT1 and FAULT2 jumpers (J10/J14) installed (optional)
    • LED jumpers (J15, J16, J6, J7) installed (optional)
  • The behavior is as follows:
    • The ‘f’ key sets forward motion
    • The ‘b’ key sets backwards motion
    • The ‘a’ key accelerates rotational speed
    • The ‘d’ key decelerates rotation speed
    • The ‘o’ key increases motor power (PWM higher duty cycle)
    • The ‘m’ key decreases motor power (PWM lower duty cycle)
  • This software is licensed under the GNU General Public License (GPL) Version
  • 3 or later. This license is described at
  • http://www.gnu.org/licenses/gpl.html
  • Application Version 1.0 – October 2010 Rugged Circuits LLC
  • http://www.ruggedcircuits.com
// Define how many steps there are in 1 revolution of your motor
#define STEPS_PER_REVOLUTION 200
YOU SHOULDN’T HAVE TO CHANGE ANYTHING BELOW THIS POINT /
// Enable (PWM) outputs
#define EN1_PIN 3
#define EN2_PIN 11
// Direction outputs
#define DIR1_PIN 12
#define DIR2_PIN 13
// Fault inputs, active low
#define FAULT1_PIN 5
// General-purpose LED’s, active high
#define LED1_PIN 10 // For motor A
#define LED2_PIN 16 // For motor B
#define LED3_PIN 17 // For motor B
Stepper stepper(STEPS_PER_REVOLUTION, DIR1_PIN, DIR2_PIN);
// Set initial default values
unsigned RPM = 10;
unsigned PWM = 25;
unsigned DIR = 1;
// Configure all outputs off for now
pinMode(EN1_PIN, OUTPUT); digitalWrite(EN1_PIN, LOW);
pinMode(EN2_PIN, OUTPUT); digitalWrite(EN2_PIN, LOW);
pinMode(DIR1_PIN, OUTPUT); digitalWrite(DIR1_PIN, LOW);
pinMode(DIR2_PIN, OUTPUT); digitalWrite(DIR2_PIN, LOW);
pinMode(LED1_PIN, OUTPUT); digitalWrite(LED1_PIN, LOW);
pinMode(LED2_PIN, OUTPUT); digitalWrite(LED2_PIN, LOW);
pinMode(LED3_PIN, OUTPUT); digitalWrite(LED3_PIN, LOW);
// Configure fault inputs with pullups
pinMode(FAULT1_PIN, INPUT); digitalWrite(FAULT1_PIN, HIGH);
// Change from divide-by-64 prescale on Timer 2 to divide by 8 to get
// 8-times faster PWM frequency (976 Hz → 7.8 kHz). This should prevent
// overcurrent conditions for steppers with high voltages and low inductance.
TCCR2B = _BV(CS21);
// Now enable PWM and start motion
analogWrite(EN1_PIN, PWM);
analogWrite(EN2_PIN, PWM);
stepper.setSpeed(RPM);
void printHelp()
Serial.println(
“f - forward motion\n”
“b - backwards motion\n”
“a - faster\n”
“d - slower\n”
“o - more power\n”
“m - less power\n”
if (Serial.available()) {
switch (Serial.read()) {
case ‘f’: case ‘F’: DIR = 1; break;
case ‘b’: case ‘B’: DIR = -1; break;
case ‘o’: case ‘O’:
if (PWM <= 250) PWM += 5;
Serial.print(“PWM=”); Serial.println(PWM);
analogWrite(EN1_PIN, PWM); analogWrite(EN2_PIN, PWM);
case ‘m’: case ‘M’:
if (PWM >= 5) PWM -= 5;
case ‘a’: case ‘A’:
RPM++;
Serial.print(“RPM=”); Serial.println(RPM);
case ‘d’: case ‘D’:
if (RPM > 1) RPM–;
case ‘h’: case ‘H’:
printHelp();
default:
Serial.println(“Unknown command”);
// This is a busy-wait loop until the inter-step time passes
stepper.step(DIR);
// Mirror phase outputs in LED’s
digitalWrite(LED1_PIN, digitalRead(DIR1_PIN));
digitalWrite(LED3_PIN, digitalRead(DIR2_PIN));
// Drive fault output LED’s as mirror of fault inputs
Thank
