New AUDRINO R3 trouble shooting
I brought the new AUDRINO UNO 3 today...made the configurations..and the setup..but i am not able to load the blink program...:frowning: However the ON LED and LED near 13 port is blinking...but the communication b/w the board and my laptop is not made.
The error it says is.
avrdude: stk500_getsync() : not in sync: resp=0x00..
i have set the
Board == Aurdino Duemilanove w/ATmega328
Programmer == AVR ISP.....
Please let me know if you are aware of such issues.. This was my first board.. and i am... :~
Board == Arduino Uno
Programmer == Arduino as ISP
Also, make sure you're using the right COM port.
And you're done.
Good luck
Thnk You.. for the prompt reponse..
I have made changes as suggested.. however same result..I am currently using COM4.. I think it is the correct port.. I checked the same.. by disconnecting the board.. and the port dissapears from the port selection. i hope i am correct in this aspect..
but i am yet to crack the crux ! !
Make sure you're using the right COM Port and your drivers are correctly installed.
cowboy432:
sometimes my IDE can not communicate, so I must to do this:
disable COM4
enable COM4
then IDE can communicate with board
I have seen the same in the device manager .. and its using the same port 4.. and updated the driver software as well..
I do not see the option to disable/enable the port back..
where exactly are these options available from IDE...Please forgive my me if my questions are basic.. i have just started to Arduino..
