I would first like to say i have spent about the last hour doing research and reading various troubleshooting topics and none seem to help. I have noticed that i need to be as specific as possible with as much detail as I can so here it goes.
I received DFRobots Arduino kit for beginners today. i opened it up laid everything out to make sure it was all there then downloaded the PDF tutorial to get started. It first told me to download the Arduino software. Then to install some drivers. the tutorial states that windows will at first fail to install the drivers however this didn't happen for me. I followed the instructions to install them anyway and windows gave a message that the current drivers for this hardware is already installed. then it instructs to check the port in device manager to see which the Arduino is connected. COM3 in my case. The next step is to upload a blink program, this code is to make the onboard LED blink. I uploaded this and it worked just fine Next is the first project. it instructs me to plug in the shield that came with it and put the bread board on top. then I am to place a black jumper from the second ground port into the breadboard row 2 column 6, then a 5MM LED short side above the jumper i just placed and the positive/longer side will be one column to the right. Next is to place a 220R resistor below the positive lead of the LED, row 2 column 7. the other end of the resistor is to be placed in row 2 column 12. Then a green jumper is placed above that connection, row 1 column 12 and the other end of the jumper to pin 10 on the shield.
I have made sure all connections are completely into the breadboard.
next the tutorial instructs me to type this code in myself as to help learn the code format.
//project -- Blinking a LED
Description: turn LED on and off every other second.
int ledpin=10;
pinMode(ledpin,OUTPUT);
digitalWrite(ledpin,HIGH);
digitalWrite(ledpin,LOW);
that is copied from the code I typed. now when I verify the code everything is ok and so I upload the code.
the L TX RX LEDs flash then go off . the LED on the breadboard does not come on.
I have replaced the LED resistor and jumpers with others to rule them out, I tried plugging the jumpers into the Arduino itself instead of the shield plugged in. I have noticed that the L LED that the first code has me blink comes on a few seconds after I upload the code however its very dim and pulses between dim and a tad bit brighter continuously.
I hope I have given enough information. I was very excited to get this kit and start working through the projects and learning all I could only to get stuck on the first project. I like to think that this will only help me learn more about it. Any help will be greatly appreciated.
