New Compilation error in rc-6 and rc-7
Hi, I've used version 2.0.0 rc6 for a while but I've strated to get his strange compilation error.
I'm using Windows 11 and I had this error on rc-6 and also on rc-7.
Anyone have any suggestions as to what it could be?
I've switched on verbose for copilation and included the output log.
Pastebin link https://pastebin.com/X4RfpF0r
It would be more convenient if you posted the error text here in code tags and even more helpful if you posted your code in the same way
Normally people complain on forums of large logs being posted and it breaks the maximum character limit of a forum post anyway so I can't post it, sorry.
I tried it in 1.8.19 and it compiles OK so Iguess I'l have to use that until a later version.
Understood, so follow the advice in
and attach the error log to a post here to avoid the need to visit another site
How did you install RC7? I don't know much about ESP but this is the relevant part of the output
Using board 'esp32doit-devkit-v1' from platform in folder: C:\Users\gadje\OneDrive\Documents1\Arduino\hardware\espressif\esp32
Using core 'esp32' from platform in folder: C:\Users\gadje\OneDrive\Documents1\Arduino\hardware\espressif\esp32
In file included from c:\users\gadje\appdata\local\arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch3\xtensa-esp32-elf\include\c++\8.4.0\xtensa-esp32-elf\no-rtti\bits\gthr.h:151,
                 from c:\users\gadje\appdata\local\arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch3\xtensa-esp32-elf\include\c++\8.4.0\ext\atomicity.h:35,
                 from c:\users\gadje\appdata\local\arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch3\xtensa-esp32-elf\include\c++\8.4.0\memory:73,
                 from C:\Users\gadje\OneDrive\Documents1\Arduino\hardware\espressif\esp32\libraries\FS\src/FS.h:24,
                 from c:\Users\gadje\OneDrive\Documents1\Arduino\libraries\TFT_eSPI-master/Processors/TFT_eSPI_ESP32.h:137,
                 from c:\Users\gadje\OneDrive\Documents1\Arduino\libraries\TFT_eSPI-master/TFT_eSPI.h:73,
                 from C:\Users\gadje\OneDrive\Documents1\Arduino\ESP Sketches\ESP32 Sketches\watchESP\watchESP.ino:1:
c:\users\gadje\appdata\local\arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch3\xtensa-esp32-elf\include\c++\8.4.0\xtensa-esp32-elf\no-rtti\bits\gthr-default.h: In function 'int __gthread_mutex_timedlock(__gthread_mutex_t*, const __gthread_time_t*)':
c:\users\gadje\appdata\local\arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch3\xtensa-esp32-elf\include\c++\8.4.0\xtensa-esp32-elf\no-rtti\bits\gthr-default.h:781:12: error: 'pthread_mutex_timedlock' was not declared in this scope
     return __gthrw_(pthread_mutex_timedlock) (__mutex, __abs_timeout);
c:\users\gadje\appdata\local\arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\gcc8_4_0-esp-2021r2-patch3\xtensa-esp32-elf\include\c++\8.4.0\xtensa-esp32-elf\no-rtti\bits\gthr-default.h:781:12: note: suggested alternative: 'pthread_mutex_trylock'
