New EdgeDebounce feature not working
Hi, Thanks for seeing this. your explanation is clear.
I will rewrite the thing so that the call from the Sketch will look like:
if (button.close() && button.rose()) {
  /Your code here
I also like the idea of disabelling the debouncer altogether.
I will get back soon.
Jacques
Changed .cpp to:
byte EdgeDebounce::update() {
  byte newStatus = debounce();
  if (MYmode == PULLUP) newStatus = !newStatus;
  if (MYstatus == OPEN && newStatus == CLOSED) { MYrose = true; Serial.print('.'); }
  else                                           MYrose = false;
  if (MYstatus == CLOSED && newStatus == OPEN) { MYfell = true; Serial.print(':'); }
  else                                           MYfell = false;
  MYstatus = newStatus;
  return newStatus;
}//update-------------------------------------------------------------------------
//statusMethods=====================================================
bool EdgeDebounce::closed() const { return MYstatus; }
bool EdgeDebounce::open()   const { return !MYstatus; }
//transition methods========================================
bool EdgeDebounce::rose() const { return MYrose; }
bool EdgeDebounce::fell() const { return MYfell; }
And sketch to:
#include <EdgeDebounce.h>
EdgeDebounce test(4, PULLUP);
  test.begin();
  int theState = test.update();
  if (test.rose()) Serial.print(',');
  if (test.fell()) Serial.print(';');
It all works now.
Thanks
Jacques
debounceDontCare = ~((1<<w)-1);
It took me a little while just to understand what the original algorithm:
bool_t DebounceSwitch2()
Static uint16_t State = 0;
State=(State<<1) | !RawKeyPressed() | 0xe000;
If(State==0xf000)return TRUE;
Return FALSE;
actually did.
I will need some time to figure out your shorthand notation... Learning opportunity :art:
Jacques
It's not shorthand, it's an expression. Suppose you pass in 16 for the variable w.
1UL<<w left-shifts a 1 by 16 spaces, producing the number 0x00010000. Note the UL suffix I added here. It's important and I forgot to put it in the original post.
From this the quantity 1 is subtracted, producing 0x0000FFFF.
~ is a bitwise inversion, producing 0xFFFF0000.
Try it again with 12.
1UL<<12 = 0x00001000
0x00001000 - 1 = 0x00000FFF
~0x00000FFF = 0xFFFFF000
Yes,
I just did some tests in Word (easy to jot down 0s and 1s)
00000000000000010000000000000000
00000000000000001111111111111111
11111111111111110000000000000000
Thanks again
