Up until now, I have only been using Arduino units. First time ever, I have purchased an ESP8266 12E to make an IoT project. Just as I usually do with Arduino unit, I tried to run a simple blink project but I am not getting normally expected results. Here is what I have:
Unit: ESP8266 12E, Vendor DOIT.AM, Model: ESP8266MOD
Connected to computer directly via USB cable. No breadboard or any other device connected.
In Arduino, I have selected: NodeMCU 1.0 (ESP-12E Module)
#define LED D0 // Led in NodeMCU at pin GPIO16 (D0).
pinMode(LED, OUTPUT); // LED pin as output.
digitalWrite(LED, HIGH);// turn the LED off.(Note that LOW is the voltage level but actually
//the LED is on; this is because it is acive low on the ESP8266.
delay(1000); // wait for 1 second.
digitalWrite(LED, LOW); // turn the LED on.
Result:
Build options changed, rebuilding all
Sketch uses 257696 bytes (24%) of program storage space. Maximum is 1044464 bytes.
Global variables use 26572 bytes (32%) of dynamic memory, leaving 55348 bytes for local variables. Maximum is 81920 bytes.
esptool.py v2.6
2.6
esptool.py v2.6
Serial port COM4
Connecting....
Chip is ESP8266EX
Features: WiFi
MAC: 2c:f4:32:57:a8:2g
Uploading stub...
Running stub...
Stub running...
Configuring flash size...
Auto-detected Flash size: 4MB
Compressed 261856 bytes to 191266...
Writing at 0x00000000... (8 %)
Writing at 0x00004000... (16 %)
Writing at 0x00008000... (25 %)
Writing at 0x0000c000... (33 %)
Writing at 0x00010000... (41 %)
Writing at 0x00014000... (50 %)
Writing at 0x00018000... (58 %)
Writing at 0x0001c000... (66 %)
Writing at 0x00020000... (75 %)
Writing at 0x00024000... (83 %)
Writing at 0x00028000... (91 %)
Writing at 0x0002c000... (100 %)
Wrote 261856 bytes (191266 compressed) at 0x00000000 in 16.9 seconds (effective 123.7 kbit/s)...
Hash of data verified.
Leaving...
Hard resetting via RTS pin...
Serial Monitor gives me some ascii characters that I can't make any sense of.
During flashing, I can see the device LED blicking etc but after that, nothing happens.
What am I doing wrong?
Thank you.
