New GPS Issue #2
EDIT, Should I be reading about typecast and lacking that a cast? It’s been bothering me since I posted this thing…
In attempting to botch some apparently simple instruction From the tinyGPS Page, TinyGPS | Arduiniana, I did this:
// First Attempt at My GPS Clock
#include <TinyGPS.h>
#include <UTFT.h>
extern uint8_t SmallFont[];
UTFT myGLCD(ITDB32S,38,39,40,41);   // Mega2560
TinyGPS gps;
//  Other init stuff to go here
//  Works ... so far W/O the display, that's after it compiles
  // Do some thing here
  Serial.begin(115200);  //Remove when GLCD is working
  Serial1.begin(9600);  // 9600 baud for Skylabs SKM53
  //Serial1.begin(4800);  // 4800 baud for uBlox-6_1?
  myGLCD.InitLCD();
  myGLCD.setFont(SmallFont);
  myGLCD.clrScr();
  // Other setup stuff to go here too
/*Feed the object serial NMEA data one character at a time using the encode() method.
 (TinyGPS does not handle retrieving serial data from a GPS unit.)
 When encode() returns “true”, a valid sentence has just changed the TinyGPS object’s internal state. For example:
  while (Serial1.available())
    int c = Serial1.read();
    if (gps.encode(c))
      // process new gps info here
      int year;
      byte month, day, hour, minute, second, hundredths;
      unsigned long fix_age;
      gps.crack_datetime(&year, &month, &day,
      &hour, &minute, &second, &hundredths, &fix_age);
      myGLCD.clrScr();
      myGLCD.print("Date   :",8 ,8);
 **Error**     myGLCD.print(month,8,40); // 'invalid conversion from 'byte' to 'const char*'
      myGLCD.print("/",8 ,56);  // Error above is one that google didn't help with or did this forum using the error message as the search term
      myGLCD.print(day,8,64);
      myGLCD.print(", 20",8,80);
      myGLCD.print(year,5,88);
    // myGLCD print example:  'myGLCD.print(string, Upper left corner Row, Upper Left corner Column)' and there are
    // other options for color and numeric length and fill color
I’m Kinda lost AGAIN,
If there anyone to take mercy on an old noob (oxymoron?)
Bob
      Serial.print(('month'),('day'), ("20"), ('year'));
You probably mean:
      Serial.print(month);
      Serial.print("/");
      Serial.print(day);
      Serial.print(", 20");
      Serial.print(year);
(You can only print one variable or constant at a time.)
Yes, I did, especially after your suggestion worked I had been aware of issues 'trying' to print more on a line but thought I did something wrong rather than run into a limitation? of Arduino's C implementation. I tried to decipher the "Cuneiform of the Compiler"... and that is usually the extent of it, except the totally weird ones... Those mean I've dropped a semicolon. Dropped two once and the compiler insisted line 7 of a 12 line block comment was the offending line. Thank You Johnwasser
Bob
The UTFT class does not, apparently, derive from the Print function, so the UTFT::print() method is not overloaded, like the Serial.print() or client.print() functions are. The UTFT::print() method expects the first argument to be a NULL terminated array of chars. month is NOT a NULL terminated array of chars, and the compiler is telling you that it has no idea how to convert a byte to a NULL terminated array of chars.
Fortunately, the sprintf() and itoa() functions do.
Paul, THANK YOU... It didn't make much sense at the time, although the guy (Hart) also used sprintf, I rather need the itoa function because Time will be a global function for several different functions that I have in mind for this device...
Bob
It was a case of what I harp on regularly… YES ME “,!,” HAD I BUT READ THE MANUAL SUPPLIED WITH THE LIBRARY… I can only surmise it was the sheer shock to find an accurate and truly helpful display MANUAL. UNHEARD Of…
I might have not spent several wasted hours trying to just get a sketch to compile. It seems the compiler is quite happy with myGLCD.printNumI(month,Xcol,Yrow);. I’ve not yet connected it to a display and GPS device. I had to take the GLCD shield and add stackable headers and an 8" extension cable for the GLCD so I can use the ports underneath the GLCD itself. The ITead shield if a great demo shield but Very little else without an intermediate shield or a 40 pin extension cable for the GLCD.
Now If… There Only was One More Really Fine Book… for “The Cuneiform of the Compiler” damn thing gives me nightmares…
Bob.
