Hi guys
doing a long time project with glass i just need to move 1 axis on a mini mill.
i connected a ball screw with nema23 2 phase 4.2 amp connect to arduino.
i can't find a sketch to move this back and forward with potentiometer. and turn buttons
( i probably just don't know where to look )
How did you connect the driver with the arduino (pls specify what Arduino type you use)? A picture would be helpful to check the connections with the manual.
Did you run your configuration in a simple sketch to see if the whole configuration works at all?
Pls specify in more detail what exactly you want to do with the potentiometer and what the buttons (how many) should be for
You are talking about a mini mill with ball screws: a Nema23 with 4.2amp seems way overpowered, depending on what you understand what a mini mill is ...
Hi guy
well this is my first cnc experience i follow instructions from the guy from nyc cnc
the video :
Use Arduino to Control a Large Stepper Motor! Part 1
i did all at the wiring from the video and found the skatch online.
the stepper is moving but no reaction or any change from the potentiometer
is it make a different if the experiment is nema34 and i use nema23
i do need power for the long run this will cut glass with high speed spindle and also metal one day..
 sensorValue = analogRead(sensorPin) + 200;
 digitalWrite(9, LOW);
 delayMicroseconds(10);    Â
 digitalWrite(9, HIGH);
 delay(sensorValue);
and let us know what happens
I have swapped HIGH and LOW because you seem to be connecting the minus connections to the I/O pins. I would normally connect minus to GND and the + connection to the I/O pin. But either should work.
I think, ENABLE is to be used to activate the driver.
Looking at the datasheet, ENA+ should be connected to Vcc and ENA- either to GND (this would activate the driver permanently or switch it ON by sending a HIGH from Arduino - this switches the output transistor and it connects GND to the cathode of the optocoupler).
Hi guys
got busy with work..
so i run the skatch "nema34_potentiometer.ino" and i got moment with controlled speed.
but i got only 1 direction ??? no change pressing the left right buttons.
try to add robin2 code i got lost with adding the void loop code in to the skatch sorry which part do i delete ...
and i didnt try the ENA yet because i have the stepper moving.
let see if i can fix the direction first.
one more question is the bread boards can be not so reliable meaning it feels like there is no electricity connections when i press on the buttons ???
Hi guys
thanks for your help,
reading you comments send me to read some more on the work follow and i found the problem.
just need to go over sketchs direction more then one time....
just missing +5 wire to the dir+
