new library arduino for TM1638 modules
Hi
TWIC
New library Arduino for TM1638 modules.
Overview
  • Name: TM1638plus
  • Description: An Arduino library to display data on a 8-digit TM1638 seven segment module
    This module is for the (KEY & LED) variant which has 8 LED's and 8 Push buttons.
TM1638plus
Thanks so much for this contribution to the Arduino project typematrix!
Am I being dense?
I’m unable to see how to extract the “button” status to carry out another function elsewhere/
I’d be grateful for a few pointers.
BrianO:
Am I being dense?
Bit late to answer I have not logged into forum in a Since September ,
the readme says
“For more information see the commented headers in header file.”
so the main documentation is in the header file.
And that states.
"Read buttons returns a byte with value of buttons 1-8 b7b6b5b4b3b2b1b0
1 pressed, zero not pressed. … "
So if user pressed S1 switch on module b0 is 1 and so on.
You can read the 8 buttons by cycling thru them with a bit shift as per the example file in examples.
or another way is to use a switch statement:
 uint8_t buttons = buttonsRead();
    switch (buttons)
      case  0x01 : //S1 Pressed 0000 0001 ; break;
      case  0x02 : // S2 Pressed 0000 0010 ; break;
      case  0x04 : // S3 Pressed 0000 0100 ; break;
      case  0x08 : // S4 Pressed 0000 1000 ; break;
      case  0x10 : // S5 Pressed 0001 0000 ; break;
      case  0x20 : // S6 Pressed 0010 0000 ; break;
      case  0x40 : // S7 Pressed 0100 0000 ; break;
      case  0x80 : // S8 Pressed 1000 0000 ; break;
Also I have released some new versions since OP It now support the TM1638 Module 16 Push buttons (16 KEY)
as well.
Tm1638plus changelog
