New library for timer1 and timer3 of the ATmega1284P
This is my very first library project:
The TimerOne library http://playground.arduino.cc/Code/Timer1 makes use of the 16-bit timer1 of the ATmega328P (Uno R3 chip). As I changed my RGB-LED project to the ATmega1284P because I wanted higher PWM solution I tried the TimerOne library. Unfortunately it doesn't run on the ATmega1284P beacuse the pin settings are somewhat hard-coded in the lib. So I changed the pin settings and then my timer1 was working.
Now the 1284P also has a timer3 (this was the reason why I switched to this controller). The TimerThree library at http://playground.arduino.cc/uploads/Code/TimerThree.zip didn't work and so I simply doubled the code of the TimerOne lib and adapted the register and pin settings, accordingly.
You can find a short description with all the links in my blog:
http://heliosoph.mit-links.info/timeronethree-library-atmega1284p/
The lib is at: https://github.com/heliosoph/TimerOneThree
In my IDE (1.0.5) everything works good, hopefully this is the same on other 1.0 versions of the IDE.
So I'm not a skilled programmer but am publishing now this lib hoping that everything works and some others find it useful.
Elektrix
