New Method to ASCII To int
Dear All,
I need to send two number to arduino using Bluetooth command line app. Then that two numbers assign to two variable and finally that two variables add together result to serial monitor
x = 3;
y = 4;
z = x+y;
Serial.println(z);
Please advice to convert ASCII to int
Here is an example of converting ASCII strings to bytes in both decimal and hex:
#include <Arduino.h>
#include <stdlib.h>
  Serial.begin(9600);             //! Initialize the serial port to the PC
  char dec_string[] = "123";
  uint8_t dec_num;
  char hex_string[] = "A5";
  uint8_t hex_num;
  dec_num = atoi(dec_string); // function from stdlib.h to convert ASCII strings into base10 numbers.
  Serial.println(dec_string);
  Serial.println(dec_num);
  hex_num = strtol(hex_string, NULL, 16); // function to convert ASCII strings into base passed as arg.
  Serial.println(hex_string);
  Serial.println(hex_num, HEX);
The output will be this:
123
123
A5
A5
Note that the general function used for hex conversion takes ~4x as long as the decimal one.
Delta_G:
Subtract '0'. Note the single quotes. You're subtracting the ascii code for zero to get an integer.
Thanks
Can I have the mathematics behind this method
Delta_G:
Go look at an ascii table and you'll see it.
As per the ascii table reduce 48 also he same
Am I write
Yes. ASCII '0' is 0x30 (or 48 decimal). ASCII '1' is 0x31 (or 49 decimal. And so on. So subtracting ASCII '0' will give the integers from 0 to 9 for the ASCII '0' to '9'.
Thanks for all
Please advice to convert two digit numbers to Integer
Like 10 11 12
PA3040:
Thanks for all
Like 10 11 12
I posted the code for that as #3. See above.
Multiply first digit by 10 and add second digit.
Example: 32 = ( 3 * 10 ) + 2
