I am starting a new Midi design that will only use the USART (Not USB)
I am using the 32U4 because I own lots of them in this time of hard to buy parts.
I have a few beginning sanity check questions that perhaps some of you may have thoughts about.
I am operating with 3.3V supplies, but I am planning to use an external 12 MHz clock. I have this available already on my board and I think that this should be OK as a maximum frequency.
1.1 The advantage is 50% more MIPs than standard 8 MHz given 3.3V operation
1.2 I don't need the USB port
1.3 Low frequency beat products are avoided given independent 8MHz and 12MHz clock
sources that are not exact 2/3 ratios.
Assuming 12 MHz, Midi should still be OK since (12000000/31250)/16 = 24
Assuming I did want to operate at 8MHz, it seems to me that the internal not perfect 8 MHz would still be fine for MIDI
The current library supports USB MIdi. Is this still the best choice? Efficiency is important. My application is a Midi to control bridge where I mostly run a parser and move data to SPI, I2C, etc.
Comments?
Al
