New operator doens't work... error with [underfined reference]
Good day guys,
i have run out of idea and find no luck to get the solution from google.
Please advise me for below.
I tried to build a linked list in arduino by referring to other c++ tutorial sample code.
#include <node.h>
void setup(){
  node *root;
  for (int i=0; i<=5; i++){
     root = new node;
     root->num = 5;
     root->link = p;
     p =root;
void loop(){
It doesn’t compiled and prompt error message :
undefined reference to 'operator new (unsigned int)…
Please advise as the same logic is compiled in other c++ ide.
What is the thing i have missed out here.
Many thanks.
Cielle
What version of the IDE are you using? Operator new should be there for 1.0.
thank you for your reply…
I am using Arduino 0022.
Hmm but my last try give me luck here.
I found the threat.
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1230935955
and adding below
#include <stdlib.h> // for malloc and free
void* operator new(size_t size) { return malloc(size); }
void operator delete(void* ptr) { free(ptr); }
after the setup and loop function solved the problem.
so is it because the arduino IDE i m using doesn’t support the new operator?
Many thanks!
The implementation doesn't include it. Looks like you found the answer. They included it in IDE 1.0.
root=new node(number);
You missed the number and parentheses.
