hai i am using two ultrasonic sensor placed 10cm apart in a solder less board...i try to build obstacle avoidance robot..
im using the following code for testing it befor implementing it with real robot.
#include <NewPing.h>
#define SONAR_NUM 2 // Number or sensors.
#define MAX_DISTANCE 200 // Maximum distance (in cm) to ping.
#define PING_INTERVAL 33 // Milliseconds between sensor pings (29ms is about the min to avoid cross-sensor echo).
unsigned long pingTimer[SONAR_NUM]; // Holds the times when the next ping should happen for each sensor.
unsigned int cm[SONAR_NUM]; // Where the ping distances are stored.
uint8_t currentSensor = 0; // Keeps track of which sensor is active.
int leftsensor, rightsensor;
NewPing sonar[SONAR_NUM] = { // Sensor object array.
NewPing(13, 12, MAX_DISTANCE), // Each sensor's trigger pin, echo pin, and max distance to ping.
NewPing(11, 10, MAX_DISTANCE),
pingTimer[0] = millis() + 75; // First ping starts at 75ms, gives time for the Arduino to chill before starting.
for (uint8_t i = 1; i < SONAR_NUM; i++) // Set the starting time for each sensor.
pingTimer[i] = pingTimer[i - 1] + PING_INTERVAL;
for (uint8_t i = 0; i < SONAR_NUM; i++) { // Loop through all the sensors.
if (millis() >= pingTimer[i]) { // Is it this sensor's time to ping?
pingTimer[i] += PING_INTERVAL * SONAR_NUM; // Set next time this sensor will be pinged.
if (i == 0 && currentSensor == SONAR_NUM - 1)
leftsensor =cm[0];
rightsensor =cm[1];
sonar[currentSensor].timer_stop(); // Make sure previous timer is canceled before starting a new ping (insurance).
currentSensor = i; // Sensor being accessed.
cm[currentSensor] = 0; // Make distance zero in case there's no ping echo for this sensor.
sonar[currentSensor].ping_timer(echoCheck); // Do the ping (processing continues, interrupt will call echoCheck to look for echo).
// The rest of your code would go here.
if ((leftsensor >=10)&& (rightsensor >=10 ))
Serial.println(" go straight");
if ((leftsensor<=10)&&(rightsensor >=10))
Serial.println(" right turn");
Serial.println("left turn ");
if ((leftsensor<=10) && (rightsensor<=10))
Serial.println(" back");
void echoCheck() { // If ping received, set the sensor distance to array.
if (sonar[currentSensor].check_timer())
cm[currentSensor] = sonar[currentSensor].ping_result / US_ROUNDTRIP_CM;
when i run this code in serial monitor .... i left both the sensors uninterrupted instead of printing "go straight" it is printing "back"...
i dont no why this happens and i think it is may be due to echo..or coz of bad reading
im planning to take median of the each sensor separately but how to do it..i know sonar.ping_median(iterations) method and have no idea about how to use it..where to write this method..
I think you want to keep the "oneSensorCycle()" function from the NewPing15Sensors example and put your code in there. That way it will execute your logic when all (both) sensors have been sensed.
// This example code was used to successfully communicate with 15 ultrasonic sensors. You can adjust
// the number of sensors in your project by changing SONAR_NUM and the number of NewPing objects in the
// "sonar" array. You also need to change the pins for each sensor for the NewPing objects. Each sensor
// is pinged at 33ms intervals. So, one cycle of all sensors takes 495ms (33 * 15 = 495ms). The results
// are sent to the "oneSensorCycle" function which currently just displays the distance data. Your project
// would normally process the sensor results in this function (for example, decide if a robot needs to
// turn and call the turn function). Keep in mind this example is event-driven. Your complete sketch needs
// to be written so there's no "delay" commands and the loop() cycles at faster than a 33ms rate. If other
// processes take longer than 33ms, you'll need to increase PING_INTERVAL so it doesn't get behind.
if (i == 0 && currentSensor == SONAR_NUM - 1) oneSensorCycle(); // Sensor ping cycle complete, do something with the results.
void oneSensorCycle() { // Sensor ping cycle complete, do something with the results.
if ((cm[0] >= 10) && (cm[1] >= 10 )) {
if ((cm[0] <= 10) && (cm[1] >= 10)) {
if ((cm[0] <= 10) && (cm[1] <= 10)) {
i think taking mean of the sensors separately will make the code better but how to use sonar.ping_median(iterations) this for two separate sensors sonar.ping_median(iterations)
