Hi
I am looking to take this program and use two Arduino's, two xbee's (Din and Dout). I only want to send the I/O High or low, to the other xbee. Using Serial Data. How do I go about this, and will it be easy, to change my program to do this.
So I want use Arduino and xbee to talk to the other Arduino and xbee, using serial Data.
So in the program I will have to change the (InPin, and the OutPin).
#define trigPin 12
#define echoPin 13
const int InPin = 3;
#define OutPin 4
#define LedPin 5
int buttonState = 0;
Serial.begin (9600);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
pinMode(OutPin, OUTPUT);
pinMode(LedPin, OUTPUT);
buttonState = digitalRead(InPin);
int duration, distance;
digitalWrite(trigPin, HIGH);
delayMicroseconds(1000);
digitalWrite(trigPin, LOW);
duration = pulseIn(echoPin, HIGH);
distance = (duration/2) / 29.1;
if (distance >= 200 || distance <= 0){
Serial.println("Out of range");
else {
Serial.print(distance);
Serial.println(" cm");
if (distance < 10)
digitalWrite(OutPin, HIGH);
digitalWrite(OutPin, LOW);
if (buttonState == HIGH && distance < 10)
digitalWrite(LedPin, HIGH);
digitalWrite(LedPin, LOW);
I think the code has to start like this to work....
#define Rx 4 // DOUT to pin 6
#define Tx 3 // DIN to pin 7
#define trigPin 12
#define echoPin 13
#define LedPin 5
SoftwareSerial Xbee (Rx, Tx);
Serial.begin(9600); // Set to No line ending;
Xbee.begin(9600); // type a char, then hit enter
else {
if (distance < 10)
if(Serial.available()) {
char outgoing = Serial.read();
Xbee.print(outgoing);
if(Xbee.available()) {
char incoming = Xbee.read();
Serial.println(incoming);
delay(50);
