New project advice and help needed!
hey guys!
i am mechanically minded, but very new with small electrics and programming.....
i have a project in mind but dont really know where to start.
I dont have knowledge in this area, but i will and have to learn it!
from what i have read and seen so fare its pretty basic!
outline of project
  • ir temp sensor 1%-5% torrance, about 2inches - 1 foot away
  • different temp signal stages (beep/light) when selected temp is met.(selected temp by button) eg 20c beeps 50c beeps tiwce
  • different buttons change the temp difference. (4 different buttons) eg 25c beeps 58c beeps tiwce
  • the buttons temps can be adjusted via other buttons
  • display showing current temp and temp when adjusting (few other features but not need now)
  • beep sound adjustable and light adjustable.
money is a pretty big issue atm. going through some tough times!
any advise on best wat to approach this project would be great.
i have a scketch that i will make a bit more clear and upload that!
Did you buy an Arduino board ?
The Arduino Uno is the easiest board to start with.
For IR contactless temperature sensor, a Melexis sensor is mostly used. I think it is the MLX90614.
Is it for cooking ? Google for : adafruit sous vide
That uses a temperature sensor, not a IR contactless one.
You can find many displays at Adafruit.com and Sparkfun.com
A I2C LCD shield can be attached to an Arduino Uno, They have often a few buttons. One of those is also used in that adafruit soud vide project. The Arduino Uno and the I2C LCD shield is a quick route to finish your project.
I have looked at the MLX90614.
the ir temp sensor need to work from about 6 inches too 2 feet away whiten the tolerances!
yes is for a type of brewing that involves heating in certain temp ranges.
but constantly changing whats being heated so its critical that its an ir sensor.
i had seen the adafruit. not the sous vide tho.
thanks!
still on the search for a suitable ir sensor
