New project may be old to you
I am new to all of this. I am working on an rfid project using an esp32, a rc522 reader and a 16x2 liquid crystal display. I cannot get past the compiling to try and load on the esp32. This is what I am getting;
WARNING: library MFRC522 claims to run on avr, STM32F1, teensy, esp8266, samd architecture(s) and may be incompatible with your current board which runs on esp32 architecture(s).
WARNING: library LiquidCrystal I2C claims to run on avr architecture(s) and may be incompatible with your current board which runs on esp32 architecture(s).
C:\Users\Mike\Documents\Arduino\libraries\MFRC522\src\MFRC522Extended.cpp: In member function 'MFRC522::StatusCode MFRC522Extended::TCL_Transceive(TagInfo*, byte*, byte, byte*, byte*)':
C:\Users\Mike\Documents\Arduino\libraries\MFRC522\src\MFRC522Extended.cpp:824:34: error: ordered comparison of pointer with integer zero ('byte*' {aka 'unsigned char*'} and 'int')
  824 |         if (backData && (backLen > 0)) {
C:\Users\Mike\Documents\Arduino\libraries\MFRC522\src\MFRC522Extended.cpp:847:42: error: ordered comparison of pointer with integer zero ('byte*' {aka 'unsigned char*'} and 'int')
  847 |                 if (backData && (backLen > 0)) {
exit status 1
Compilation error: exit status 1
I haven't got a clue and not afraid to admit it. I got the project from a you tuber here : https://www.youtube.com/watch?v=xeHBKi0GLow
Can anyone help me out here??????????
it looks as though the statement should be using the dereference operator *
if (backData && (*backLen > 0)) {
looking at my ESP32 code I have used the Arduino_MFRC522v2 library
Welcome to the forum
The most significant part of the error message should be obvious to you
The library is not compatible with your processor
I have used the MFRC522v2 library on an ESP32
test with SD card and MFRC522
some Serial monitor output
ESP32 SD card test - note VCC to 5V
Read MRFC522 RFID card save time and data to SD card
SD Card Type: SDHC
SD Card Size: 14992MB
Listing directory: /
  DIR : System Volume Information
  FILE: test.txt  SIZE: 1048576
  FILE: data.txt  SIZE: 891
Total space: 14984MB
Used space: 2MB
open MRFC522 RFID readerFirmware Version: 0x92 = v2.0
dDeleting file: /data.txt
File deleted
Friday, January 01 2021 01:00:14
 Card UID: ZZ XX FD C2  PICC type: MIFARE 1KB
Friday, January 01 2021 01:00:18
 Card UID: Z0 XF 62 1A  PICC type: MIFARE 1KB
Friday, January 01 2021 01:00:19
Friday, January 01 2021 01:00:22
Friday, January 01 2021 01:00:23
Friday, January 01 2021 01:02:30
People find guns all the time,
How do they know which end to look into ?
