new project
Hello I am an experienced programmer and I need to develop some software on an Arduino UNO.
The project has 2 parts:
a realtime part which is already written and tested
a non real time part which is to be tested.
the application uses one serial port and we use LINUX for software development.
I need a real debugger (see variables, breakpoints) and not a print function and I cannot use the serial port for debugging since the serial port is used by the application.
I understand this means I need a "hardware kit’ in between my arduino board and my PC . Can you confirm my understanding? Is the ATMEL ICE the right equipment or is there anything newer for a reasonable price?
I also need an IDE. I do not need fancy features for the IDE. Just the possibility to have several modules and load them when needed. I also need to have different folders for tests and software and also for different versions of the software. Is the Arduino IDE OK or should I use Eclipse or another IDE runinng under LINUX?
I thank you in advance for your advices.
Which Arduino? This matters a lot because not all solutions are applicable to all Arduinos.
Atmel ICE is a good choice. Then get gdb ... here are 2 links to get you started:
http://winavr.sourceforge.net/AVR-GDB_and_AVaRICE_Guide.pdf
You might want to look at ddd or nemiver, if you like it more gui-style.
“I need a real debugger (see variables, breakpoints) and not a print function and I cannot use the serial port for debugging since the serial port is used by the application.”
Interesting.
You can flash a LED, use i2c, SPI or a second serial port.
A mega has several ports.
Most here debug small sections of code as they are written then proceed to the next . . .
Sounds like a bit of an enthusiast with an XY problem! :astonished:
If you are an experienced programmer I wonder why you need to set break points and the other stuff on such a simple platform as an Arduino? Most inexperienced folks don’t need them.
Grumpy_Mike:
I suspect it's a status thing. "real programmers use break-points" :slight_smile:
...R
Hello
Nothing to do with a status thing. More with comfort and productivity!....
May be it is doing without a debugger that is a status thing !....
Thanks for your replies anyhow!...
piscvau:
In the AVR world, Is there such thing as “non real time” code?
Everything is loaded on the MCU and then it runs.
Is this second part just a new subroutine, function, library, branch or what?
Grumpy_Mike:
Still not answered that.
Slumpert:
It is state machine for a communication protocol , a buffer manager and functions to send messages and receive messages on the serial line.
Grumpy_Mike:
Allergic to giving out information, maybe you simply don’t want an answer?
I think we knew that from the first post. Creative head-banging it seems. :grinning:
