New RTC DS3234 Sketch with SD Reader
So the experts say it looks like my sd reader may not have a logic level converter, so my reader and the rtc are incompatible. so I found a sketch/ library that will allow my to move the spi pins for the rtc and its almost working. it is displaying the correct time month and day and day of the week however the year says 1915. any help will be appreciated.
//  Cheap & dirty test/demo program for the DS3234 library
//  Plug Sparkfun "Dead On" RTC board into Arduino as follows:
//	   _______________
//	  |   _________   |
//	  |  [ DS-3234 ]  |   GND  -> GND
//	  |  [_________]  |   VCC  -> VIN
//	  |               |   SQW  -> the gap
//	  | S M M C S V G |   CLK  -> A0
//	  | S O I L Q C N |   MISO -> A1
//	  |   S S K W C D |   MOSI -> A2
//	  |   I O         |   SS   -> A3
//	__________________________________________  DO NOT USE!
//	A A A A A A   V G G 5 3 R I        |     || EXTERNAL
//	5 4 3 2 1 0   I N N V . E O        |_____|| POWER JACK
//	              N D D   3 S R               |
//	                      V E E    ARDUINO    |
//	                        T F     BOARD     |
#include <DS3234.h>
static DS3234 RTC; // DS3234 object
const uint8_t GND_PIN  = 99; // bogus pin number because we have a real ground
const uint8_t VCC_PIN  = A5;
const uint8_t SQW_PIN  = A4;
const uint8_t CLK_PIN  = A0;
const uint8_t MISO_PIN = A1;
const uint8_t MOSI_PIN =  A2;
const uint8_t SS_PIN   =  A3;
void setup (void)
	Serial.begin (115200);
	digitalWrite (GND_PIN, LOW); // bogus but needed if a different pin is used
	digitalWrite (VCC_PIN, HIGH); // steal VCC from Arduino port
	pinMode (GND_PIN, OUTPUT); // turn on GND and...
	pinMode (VCC_PIN, OUTPUT); // ... power pins.
	pinMode (SQW_PIN, INPUT); // don't load the SQW pin
	_delay_ms (100);
	// the driver returns error codes upon initialization:
	// 0 = Init OK
	// 1 = Oscillator has been stopped in the past or never was on
	// 2 = Stored Day of Week and calculated Day of Week do not match
	// 3 = Both errors
	// if the init returns non-zero, the time is probably wrong
	// and should be corrected or (re)set.
	const char *initmsg[] = {
		"RTC Initialized OK",
		"RTC oscillator was stopped - time not accurate",
		"Stored Day of Week mismatch - time not accurate",
		"Oscillator and Day Of Week failure - time not accurate"
	uint8_t init_status = RTC.init (CLK_PIN, MISO_PIN, MOSI_PIN, SS_PIN); // init the RTC chip
	Serial.println (initmsg[init_status]); // show startup status
	//	to set the RTC chip:
	//	hour = 0; // setup proper time
	//	minute = 43;
	//	second = 0;
	//	month = 12;
	//	date = 14;
	//	year = 2013;
	//	d_week = RTC.writeTime(hour, minute, second, month, date, year);
// "walking bits" ram test
uint8_t test_sram (void)
	uint8_t data;
	uint8_t prev_data;
	uint16_t address;
	uint16_t errors;
	data = 0b00000000;
	errors = 0;
	for (address = 0; address < 256; address++) {
		RTC.writeByte (address, data); // fill ram with 0
	do {
		Serial.print (".");
		prev_data = data; // copy old data
		data <<= 1; // shift up a bit
		data |= 1; // or in a bit
			if (prev_data != RTC.readByte (address)) {
				errors++;
	} while (data != 0b11111111);
	do {
		Serial.print (".");
		data &= ~1; // and off bit 0
				errors++;
	} while (data != 0b00000000);
	return errors;
void loop (void)
	uint8_t hour;
	uint8_t minute;
	uint8_t second;
	uint8_t old_second = 0xFF; // invalidate old_sec
	uint8_t day_of_week;
	uint8_t month;
	uint8_t day;
	uint16_t year; // 16 bits because year is full i.e. "2013".
	uint8_t test8;
	uint16_t test16;
	uint32_t test32;
	uint64_t test64;
	float testf;
	char buffer[64];
	const char *text[] = {
		"\r\nTime: %02d:%02d:%02d\r\n",
		"Date: %s, %02d %s %04d\r\n",
		"Testing SRAM, please wait",
		"\r\nSRAM test: %d error%s\r\n",
		"Chip temperature is: %.2f deg C\r\n",
		"Chip temperature is: %.2f deg F\r\n",
		"Writing uint8_t value to chip %u\r\n",
		"Read back uint8_t value %u from chip\r\n",
		"Writing uint16_t value to chip %u\r\n",
		"Read back uint16_t value %u from chip\r\n",
		"Writing uint32_t value to chip %lu\r\n",
		"Read back uint32_t value %lu from chip\r\n",
		"Writing float value to chip %.3f\r\n",
		"Read back float value %.3f from chip\r\n",
	const char *days[] = {
		"SUN", "MON", "TUE", "WED", "THU", "FRI", "SAT"
	const char *months[] = {
		"NUL",
		"JAN", "FEB", "MAR", "APR", "MAY", "JUN",
		"JUL", "AUG", "SEP", "OCT", "NOV", "DEC"
	do { // get time, wait until time changes to print it
		day_of_week = RTC.readTime (&hour, &minute, &second, &month, &day, &year);
	} while (old_second == second);
	old_second = second; // prepare for next second
	// print first message (time)
	sprintf (buffer, text[0], hour, minute, second);
	Serial.print (buffer); // display time
	// print second message (date)
	sprintf (buffer, text[1], days[day_of_week], day, months[month], year);
	Serial.print (buffer); // display date
	// "testing sram" message
	sprintf (buffer, text[2], days[day_of_week], day, months[month], year);
	// test the SRAM
	uint16_t errors = test_sram ();
	// show if there were errors
	sprintf (buffer, text[3], errors, (errors == 1) ? "" : "s");
	Serial.print (buffer); // display ram test results
	// show chip temp degrees C
	sprintf (buffer, text[4], RTC.readTempC());
	// show chip temp degrees F
	sprintf (buffer, text[5], RTC.readTempF());
	test8 = 123;
	RTC.writeByte (0, test8);
	sprintf (buffer, text[6], test8);
	test8 = 0; // erase it
	test8 = RTC.readByte (0); // read it back
	sprintf (buffer, text[7], test8);
	test16 = 45678;
	RTC.writeWord (0, test16);
	sprintf (buffer, text[8], test16);
	test16 = 0; // erase it
	test16 = RTC.readWord (0); // read it back
	sprintf (buffer, text[9], test16);
	test32 = 1234567890;
	RTC.writeDWord (0, test32);
	sprintf (buffer, text[10], test32);
	test32 = 0; // erase it
	test32 = RTC.readDWord (0); // read it back
	sprintf (buffer, text[11], test32);
	testf = 1234.567890;
	RTC.writeFloat (0, testf);
	sprintf (buffer, text[12], testf);
	testf = 0; // erase it
	testf = RTC.readFloat (0); // read it back
	sprintf (buffer, text[13], testf);
DS3234.cpp (8.8 KB)
DS3234.h (2.5 KB)
keywords.txt (1.94 KB)
