New Servo.h, old code
I've started working on my bot again, and it seems that the servo lib has changed a lot.
I'm not real good with coding, so I could use some advice.
This is my original code:
#include <Servo.h>     // includes the servo libs
Servo LeftServo;       // name the servo
Servo RightServo;      // name the servo
int ultraSoundSignal = 7; // Ultrasound signal pin
int val = 0;
int val2 = 0;
int ultrasoundValue = 0;
int timecount = 0; // Echo counter
int ledPin = 13; // LED connected to digital pin 13
int lightSense = 2;
int headLight = 8;
void setup(){
   pinMode(6,OUTPUT);
   pinMode(5,OUTPUT);
   LeftServo.attach(6);       // Attaches the Left Servo to PWM pin 6 on the Arduino
   RightServo.attach(5); // Attaches the Right Servo to PWM pin 5 on the Arduino
   pinMode(headLight, OUTPUT);
   pinMode(lightSense, INPUT);
   beginSerial(9600);                  // Sets the baud rate to 9600
   pinMode(ledPin, OUTPUT);            // Sets the digital pin as output
void moveServoLeftTo(int angle, int duration){
  // command the servo to move to the given angle for the given number of milliseconds
   LeftServo.write(angle);
   for( ; duration > 0; duration -= 20){  // loop for the given number of milliseconds by subtracting 20ms each iteration
       //LeftServo.refresh();             // call the service routine to move the servo
       delay(20);                      // wait 20 milliseconds  between each refresh
void moveServoRightTo(int angle, int duration){
   RightServo.write(angle);
       //RightServo.refresh();            // call the service routine to move the servo
 // Ping))) functions: Doing more than I need it to, I think, but code
 timecount = 0;
 val = 0;
 pinMode(ultraSoundSignal, OUTPUT);   // Switch signalpin to output
  digitalWrite(ultraSoundSignal, LOW);  // Send low pulse
  delayMicroseconds(2);                 // Wait for 2 microseconds
  digitalWrite(ultraSoundSignal, HIGH); // Send high pulse
  delayMicroseconds(5);                 // Wait for 5 microseconds
  digitalWrite(ultraSoundSignal, LOW);  // Holdoff
  pinMode(ultraSoundSignal, INPUT);     // Switch signalpin to input
  val = digitalRead(ultraSoundSignal);  // Append signal value to val
  while(val == LOW) {                   // Loop until pin reads a high value
  while(val == HIGH) {                  // Loop until pin reads a high value
  timecount = timecount +1;           // Count echo pulse time
ultrasoundValue = timecount;          // Append echo pulse time to ultrasoundValue
if(timecount > 0){
  digitalWrite(ledPin, HIGH);
//delay(1);
// Servo functions: The basics
  if(ultrasoundValue > 500){
      moveServoLeftTo(45,50);   // move the left servo to 45 degrees for 500 milliseconds
      moveServoRightTo(180,50);  // moveRightTo function is left as an excercise ;)
  if(ultrasoundValue < 500){
      moveServoLeftTo(180,40);
      moveServoRightTo(180,40);
     if(ultrasoundValue < 100){
      moveServoLeftTo(180,100);
      moveServoRightTo(45,100);
      //moveServoLeftTo(45,50);
      //moveServoRightTo(180,50);
// Headlight - Turns on when photoresistor is triggered
// Doesn't seem to work on the same circuit... not sure why yet.
/*  val2 = digitalRead(lightSense);  // read input value
  if (val == HIGH) {            // check if the input is HIGH
    digitalWrite(headLight, LOW);  // turn LED OFF
    digitalWrite(headLight, HIGH); // turn LED ON
Which used to work fine, but now gives this error when compiling:
In function 'void moveServoLeftTo(int, int)':
error: 'class Servo' has no member named 'refresh' In function 'void moveServoRightTo(int, int)':
As I understand it, the refresh is done by hardware now, and no longer needed. Simply removing the '.refresh();' lines leads to a whole slew of other errors.
What do I need to change to get this going?
You're using code that has been written for the SoftwareServo library, while you're using the Servo library. They used to share the name "Servo", but to avoid problems like this, one was moved to SoftwareServo.
See the bottom of the Servo page on the wiki for an example of how to modify your code.
The wiki page can be found at Arduino Playground - Servo
Thank you!!
