New sound module library
I saw this sound module on ebay
a great project was posted by Kathy here:
http://www.elecfreaks.com/7079.html
sounds promising with big capacity..
Did anyone see a library to use it ?
Goldenshuttle:
This thingy looks much the same as the "Instabot Laser Harp" assembly kit.
It is just providing some kind of "touchless on/off buttons" as a hardware.
You can use those on/off buttons as you like in your sketch.
The typical "piano" or "harp" player would possibly react on pressed buttons (interrupted laser beam) by playing a small WAV sample depending on the tone pitch.
So for low quality sound you could either use the Arduino "tone()" function or play WAV sound samples of a real piano or harp note from the PROGMEM flash memory or from a file on SD card. For high quality sound you could use a sound player module or a synthesizer module to play sound.
The hardware provides just a number of touchless on/off momentary switches by using laser modules.
