Hi friends,
I´m new in this forum and I need some help.
The display on my Goldwing 1500 is broken and I try to replace it by one like you can see in the attachment.
I already made some projects with Arduino Mega2560 by using sensors, swiches and 16/2 displays.
For the TFT I bought now, I could not find neither an appropriate library to include, nor sample sketches to learn about it.
Could you please help?
Thank You in advance!
Should work with UTFT library. Model ILI9486
Or work better and faster with Bodmer's TFT_HX8357 library. Select ILI9486 in User_Setup.h file
David,
THANK YOU!!!!
Spent half the night testing and everything works fine!
The only thing I need now, I guess, is another library to work with the SD Card. Can You please recommend one?
Again, thank you for the quick and perfect help!
The SD.h library should work with your shield. It uses pins 50-53 (which are the Mega2560 hardware SPI pins)
