Hello,
I need some help explaining/guiding how to send and receive MPU6050 accelerometer data with Adafruit Feather M0 to work with a NeoPixel FeatherWing.
Trying to run the code and calibration script calculating an angle based on the two axis changes that can be detected by the led. However, I am trying to understand if I am over complicating my script, or I missed a step when calibrating the clock and data translation between the i2c and MO.
an issue I had at first was a: TWBR error ???
I read from the Adafruit page something about adapting the script to include: TinyWireM.begin(); on line 143
After I done this, I started getting this compiling error on line 30:
30 | #include <util/delay.h>
Again i'm trying to learn, any help or feedback would be greatly appreciated.
Thank you!
#include <TinyWireM.h>
#include "I2Cdev.h"
#include "MPU6050_6Axis_MotionApps20.h"
#include <Arduino.h>
#ifdef __AVR__
#include <avr/power.h> // Required for 16 MHz Adafruit Trinket
#endif
#define NEOPIXED_CONTROL_PIN 6
#define NUM_LEDS 32
#if defined(ARDUINO_SAMD_ZERO) && defined(SERIAL_PORT_USBVIRTUAL)
// Required for Serial on Zero based boards
#define Serial SERIAL_PORT_USBVIRTUAL
#endif
const int MAX_ANGLE = 45;
const int LED_OFFSET = 12;
MPU6050 mpu;
Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUM_LEDS, NEOPIXED_CONTROL_PIN, NEO_RBG + NEO_KHZ800);
unsigned long lastPrintTime = 0;
bool initialization = false; // set true if DMP init was successful
uint8_t mpuIntStatus; // holds actual interrupt status byte from MPU
uint8_t devStatus; // return status after each device operation (0 = success, !0 = error)
uint16_t packetSize; // expected DMP packet size (default is 42 bytes)
uint16_t fifoCount; // count of all bytes currently in FIFO
uint8_t fifoBuffer[64]; // FIFO storage buffer
Quaternion q; // [w, x, y, z] quaternion container
VectorFloat gravity; // [x, y, z] gravity vector
float ypr[3]; // [yaw, pitch, roll] yaw/pitch/roll container and gravity vector
volatile bool mpuInterrupt = false; // indicates whether MPU interrupt pin has gone high
#if defined(__AVR_ATtiny85__) && (F_CPU == 16000000)
clock_prescale_set(clock_div_1);
#endif
// END of Trinket-specific code.
pixels.begin(); // INITIALIZE NeoPixel strip object (REQUIRED)
Serial.println("Program started");
initialization = initializeGyroscope();
strip.begin();
if (!initialization) {
return;
mpuIntStatus = mpu.getIntStatus();
fifoCount = mpu.getFIFOCount();
if (hasFifoOverflown(mpuIntStatus, fifoCount)) {
mpu.resetFIFO();
return;
if (mpuIntStatus & 0x02) {
while (fifoCount < packetSize) {
mpu.getFIFOBytes(fifoBuffer, packetSize);
fifoCount -= packetSize;
mpu.dmpGetQuaternion(&q, fifoBuffer);
mpu.dmpGetGravity(&gravity, &q);
mpu.dmpGetYawPitchRoll(ypr, &q, &gravity);
redrawLeds(ypr[0] * 180/M_PI, ypr[1] * 180/M_PI, ypr[2] * 180/M_PI);
boolean hasFifoOverflown(int mpuIntStatus, int fifoCount)
return mpuIntStatus & 0x10 || fifoCount == 1024;
void redrawLeds(int x, int y, int z)
x = constrain(x, -1 * MAX_ANGLE, MAX_ANGLE);
y = constrain(y, -1 * MAX_ANGLE, MAX_ANGLE);
if (y < 0 and z > 0) {
lightLeds(y, z, 0, 5, 0, 89);
} else if (y < 0 and z < 0) {
lightLeds(y, z, 6, 12, 89, 0);
} else if (y > 0 and z < 0) {
lightLeds(y, z, 13, 19, 0, 89);
} else if (y > 0 and z > 0) {
lightLeds(y, z, 20, 24, 89, 0);
void lightLeds(int x, int y, int fromLedPosition, int toLedPosition, int fromAngle, int toAngle)
double angle = (atan((double) abs(x) / (double) abs (y)) * 4068) / 71;
int ledNr = map(angle, fromAngle, toAngle, fromLedPosition, toLedPosition);
printDebug(x, y, ledNr, angle);
uint32_t color;
for (int i=0; i < NUM_LEDS; i++) {
color = strip.Color(0, 0, 0);
if (i == ledNr) {
color = strip.Color(0, 180, 0);
} else if (i == ledNr - 1) {
color = strip.Color(0, 5, 0);
strip.setPixelColor(normalizeLedPosition(i), color);
strip.show();
int normalizeLedPosition(int position)
if (NUM_LEDS > position + LED_OFFSET) {
return position + LED_OFFSET;
return position + LED_OFFSET - NUM_LEDS;
void printDebug(int y, int z, int lightLed, int angle)
if (millis() - lastPrintTime < 500) {
return;
Serial.print("a=");Serial.print(angle);Serial.print("; ");
Serial.print("ll=");Serial.print(lightLed);Serial.print("; ");
Serial.print("y=");Serial.print(y);Serial.print("; ");
Serial.print("z=");Serial.print(z);Serial.println("; ");
lastPrintTime = millis();
bool initializeGyroscope() {
TinyWireM.begin();
TWBR = 24;
mpu.initialize();
Serial.println(mpu.testConnection() ? F("MPU6050 connection successful") : F("MPU6050 connection failed"));
Serial.println(F("Initializing DMP..."));
devStatus = mpu.dmpInitialize();
mpu.setXGyroOffset(220);
mpu.setYGyroOffset(76);
mpu.setZGyroOffset(-85);
mpu.setZAccelOffset(1788);
if (devStatus != 0) {
Serial.print(F("DMP Initialization failed (code "));Serial.println(devStatus);
return false;
mpu.setDMPEnabled(true);
Serial.println(F("Enabling interrupt detection (Arduino external interrupt 0)..."));
attachInterrupt(0, dmpDataReady, RISING);
Serial.println(F("DMP ready! Waiting for first interrupt..."));
packetSize = mpu.dmpGetFIFOPacketSize();
return true;
void dmpDataReady()
mpuInterrupt = true;
