hi there...I new to arduino and C, programming experience in PowerBASIC and assembler,
having trouble using channelabels, using automation direct P1AM processer, the error message is
"cannot convert 'channelLabel' to 'uint32_t (aka long unsigned int) for argment '1' to 'int digiitalRead(uint32_t)'
#include <P1AM.h>
void setup() { // the setup routine runs once:
Serial.begin(115200); //initialize serial communication at 115200 bits per second
while(!P1.init())
; //wait for Modules to sign on
- I/O assignments
- labels for outputs SLOT-1 P1-15TD2 MODULE 16 points of INPUT
channelLabel ZaxisDIRECTION = {1,1}; // SLOT-1 - CH-1: z-axis dirEction control 1=UP / 0= DOWN
channelLabel SINGLATE = {1,2}; // SLOT-1 - CH-2: singlator air cylinder 1=singlate / 0= pick
channelLabel VACUUM = {1,3}; // SLOT-1 - CH-3: vacuum generator solenoid 1=vacuum on / 0= vacuum off
channelLabel XaxisAIRcylinder = {1,4};// SLOT-1 - CH-4: x-axis air cylinder 1=load / 0= home
channelLabel GREENlight = {1,5}; // SLOT-1 - CH-5: green light control 1=on / 0= off
channelLabel REDlight = {1,5}; // SLOT-1 - CH-6: red light control 1=on / 0= off
- labels for inputs SLOT-2 P2-16ND3 MODULE 16 points of OUTPUT
channelLabel ZaxisHOME = {2,1}; // SLOT-2 - CH-1: z-axis home position sensor 1=home / 0= not-home
channelLabel ZaxisSIGNdetect = {2,2}; // SLOT-2 - CH-2: z-axis sign detection sensor 1=sign present / 0= not-sign present
channelLabel VACUUMsignDETECT = {2,3}; // SLOT-2 - CH-3: vacuum cup sign detection sensor 1=sign present / 0= not-sign present
channelLabel ESTOPswitch = {2,4}; // SLOT-2 - CH-4: e-stop switch 1=not-e-stop / 0= e-stop
channelLabel RUNstopSWITCH = {2,5}; // SLOT-2 - CH-5: run / stop switch 1=run / 0= stop
channelLabel CYCLEstartSWITCH = {2,6}; // SLOT-2 - CH-6: cycle start switch 1=not start / 0= start
channelLabel XaxisHOME = {2,7}; // SLOT-2 - CH-7: x-axis home position sensor 1=home / 0= not-home
channelLabel XaxisLOAD = {2,8}; // SLOT-2 - CH-8: x-axis load position sensor 1=load / 0= not-load
- labels for inputs SLOT-3 P1-04PWM MODULE 4 channels fo PWM OUTPUT
float dutyCycle = 50.15; //sets dutyCycle variable to 50.15
int frequency = 100; //sets frequency variable to 10000Hz
void begin
void loop() { // the loop routine runs over and over again forever:
P1.writeDiscrete(HIGH,GREENlight); //green light control= ON
delay(500); //wait .5 second
P1.writeDiscrete(LOW,GREENlight); //green light control= OFF
if (digitalRead(CYCLEstartSWITCH) == LOW)// SLOT-2 - CH-6: cycle start switch 1=not start / 0= start
Call a RUNmachine
/else if (digitalRead int(ESTOPswitch) == LOW)// SLOT-2 - CH-4: e-stop switch 1=not-e-stop / 0= e-stop
Call a ESTOPmachine
void RUNmachine();
// machine running area
void ESTOPmachine();
void loopESTOP() { // the loop routine runs over and over again forever:
P1.writeDiscrete(HIGH,ESTOPswitch); //red light control= ON
P1.writeDiscrete(LOW,ESTOPswitch); //red light control= OFF
if (digitalRead(ESTOPswitch) == HIGH)// SLOT-2 - CH-4: e-stop switch 1=not-e-stop / 0= e-stop
Call a RESETmachineFROMestop
void RESETmachineFROMestop();
// reinitialize machine after e-stop condition
// re-home z-anis
// reset all air cylinders to home postions
having trouble using channelabels, using automation direct P1AM, the error message is
#include <P1AM.h>
while(!P1.init())
* I/O assignments
* labels for outputs SLOT-1 P1-15TD2 MODULE 16 points of INPUT
* labels for inputs SLOT-2 P2-16ND3 MODULE 16 points of OUTPUT
* labels for inputs SLOT-3 P1-04PWM MODULE 4 channels fo PWM OUTPUT
void begin
Call a RUNmachine
Call a ESTOPmachine
void RUNmachine();
// re-home z-anis
