New to Arduino: Error, expeced primary-expression before '=' token
Hey guys,
I'm new to the arduino board, and I'm trying to use the board to measure temperature using a thermistor. Here is my code but I keep getting this error before the double data_raw = analogRead(READING_PIN) line
#include <math.h>
#define READING_PIN = 0
double R1 = 5600; //resistance
double V_IN = 5.0;
double A = .0013;
double B = 2.5306e-4;
double C = 8.76741e-8;
double K = 0.5; // mW/dec C - dissipation factor
double Hart(double R)
//calculate temperature
double logR = log(R);
double logR3=logRlogRlogR;
return 1.0/(A+BlogR+ClogR3);
void setup(){
double data_raw = analogRead(READING_PIN);
//Serial.println(data_raw);
double V = data_raw/1024*V_IN;
Serial.print("V=");
Serial.print(V);
//calculate resistance
double R_th = (R1*V)/(V_IN-V);
Serial.print("V R_th= ");
Serial.print(R_th);
double kelvin = Hart(R_th)-VV/(KR_th);
double celsius = kelvin - 273.15;
Serial.print("Ohm - T = ")
Serial.print(celsius);
Serial.print("C\n");
Here's your problem:
You don't use defines like that...it should be
#define READING_PIN 0
Good luck!
magagna:
Or beter yet:
const int READING_PIN = 0;
And you forgot a semi-colon.
Serial.print("Ohm - T = ");
Or beter yet:
By convention, all capital letter names are reserved for #define'd names so that they are KNOWN not to be variables (const or otherwise). So, I disagree that that is better. Unless you change the name to mixed case.
