I'm new to programming Arduino so I have no idea what I'm doing. I am trying to set up an led strip to slowly fad through colors and I want to be able to define the RGB separately and just add 1 every loop down the strip but I have no idea what I'm doing and am getting an expected primary-expression before error. and have no idea what it means
#include <FastLED.h>
#define DATA_PIN 2
#define NUM_LEDS 60
#define R 0
#define G 0
#define B 0
CRGB leds[NUM_LEDS];
FastLED.addLeds<NEOPIXEL, DATA_PIN>(leds, NUM_LEDS);
for(int i=0; i<NUM_LEDS; i++){
leds[i] = CHSV(R, G, B,);
FastLED.show();
delay(50);
R + 1
G + 1
B + 1
Full Error
Arduino: 1.8.19 (Windows Store 1.8.57.0) (Windows 10), Board: "Arduino Nano, ATmega328P (Old Bootloader)"
C:\Users\ME\Documents\Arduino\sketch_sep05a\sketch_sep05a.ino: In function 'void loop()':
sketch_sep05a:18:23: error: expected primary-expression before '(' token
sketch_sep05a:18:32: error: expected primary-expression before ')' token
sketch_sep05a:6:11: error: expected ';' before numeric constant
#define G 0
C:\Users\ME\Documents\Arduino\sketch_sep05a\sketch_sep05a.ino:22:9: note: in expansion of macro 'G'
G + 1
exit status 1
option enabled in File -> Preferences.
#define means the following is a constant and cannot be changed. Declare the variables so that they may be changed if you want to increment them later.
Here is your code so that it will compile.
#define DATA_PIN 2
#define NUM_LEDS 60
// variables declared so that they may be changed
// declared as byte since the max value is 255
byte R = 0;
byte G = 0;
byte B = 0;
for (int i = 0; i < NUM_LEDS; i++)
leds[i] = CHSV(R, G, B); // remove the extra comma
FastLED.show();
delay(50);
// properly increment a variable
R += 1;
G += 1;
B += 1;
Kudos for a very well formed first post. Full code posted in code tags plus the entire error message. You probably have no idea how rare it is for a new user to make such a great first post. Big thumbs up.
You are using the Hue/Saturation/Value color model with Saturation and Value both 0. That will always produce BLACK, regardless of what Hue of BLACK you select.
Try setting Saturation and Value to the midpoint (128) so you can see the change in Hue.
Or you could use CRGB() instead of CHSV(). That will allow you to see the Red intensity go up.
Your best troubleshooting tool is the serial print. Use serial prints to follow execution of the code and monitor variable values. See below where I start the serial port (Serial.begin(9600);) and add serial prints to watch the value of R. I also slow execution down (delay(500);) so the serial port does not flood. I do see the value of R changing so something else is going on so that you do not see the changes. @johnwasser has the answer to that.
#define DATA_PIN 2
#define NUM_LEDS 60
// int data type wastes a byte for each variable
byte R = 1;
byte G = 1;
byte B = 1;
Serial.print("value of R = ");
Serial.println(R);
FastLED.show();
R++;
Output:
11:00:25.245 -> value of R = 1
11:00:25.735 -> value of R = 2
11:00:26.266 -> value of R = 3
11:00:26.755 -> value of R = 4
11:00:27.245 -> value of R = 5
11:00:27.772 -> value of R = 6
11:00:28.259 -> value of R = 7
11:00:28.787 -> value of R = 8
11:00:29.272 -> value of R = 9
11:00:29.762 -> value of R = 10
11:00:30.290 -> value of R = 11
11:00:30.778 -> value of R = 12
