New to Arduino - Wanting to flash a led a few counts pause and few counts again
Could anyone tell me how 'C', being a subset of C++, is more versatile than its own superset 'C++'.
Ok how about this question to go with yours, why would anyone create subsets if the original is good enough. So there has to be a difference or else it wouldn't be there!
I have found Arduino is C/C++ AVR GCC
I guess I should have taken the post of topic!
@adigitaldj1
I am a scorpio and were naturally introverted
Well, I have that in common... Thank to let me know what state/Province. I hear Ohio State trouper are a "bit picky"...
About you problem in coding... C++ is a different ball game than BASIC.
I re-read this tread, It look like you want : press button, flash the light in the sequence you want, no press, no light flashing .... I am correct ? OK let assume that... Programing the Arduino, you have to know what you want to do.
Here is a concept code :
  // your pin setup
    read the switch
if swich is on = state = on
   while(state)
      flash the light
    re-check the switch
if switch is on  = state on
if no on, state  = off
I did a code simila to that. It my school bus light system. Just re-modify this code to fit your need.
Here the code :
  Version 2.1
  file name : schoolbussignal.pde
  School Bus Alternating Light Simulator
  It simulate the activation system to activate the alternating
  red light, stop sign and crossing gate of the school bus.
  Here the parts you need :
  4 - 330 ohms limiting resistors for the LED's
  2 - Red LED
  2 - Green KED
  3 - 10 K resistor pull-down resistor
  2 - SPDT or SPST switch or DIP switch
  1 - Push-on button switch
  How it work :
  1. To activate the system, turn on MASTER switch.
  2. Press the push button to activate the Red Lights ONLY.
  3. When the door is open, a swtich is close ( the door switch is ON )
     and activate the stop sign ( left side of the bus )
     and crossing ( front of the bus ) gate.
  4. Close the door ( turn the door off ) to turn off everythings.
  5. When open the door ( turn on/off door switch ) and
     Master switch is OFF, nothing will happen.
  6. Even you press the push button and the Master switch is OFF,
  Program by Serge J Desjardins aka techone
  Re-Modify with the help of AWOL
  Compile and Tested
// input pin
const byte masterpin=12;
const byte doorpin=11;
const byte pushbuttonpin=10;
   pin 12 : Master Switch
   pin 11 : Door Switch
   pin 10 : Push button to activate
// output pin
const byte busoutpin[4]={9,8,7,6};
   pin 7 : Alterning Light A
   pin 6 : Alterning Light B
   pin 5 : Front gard gate motor on/off
   pin 4 : Stop sign motor on/off
byte master=0; // Master Switch
byte door=0;  // Door Switch
byte pushbutton=0; // Push Button
boolean buttonstate; // State Control
boolean doorstate;
{ // init out & in pin
  pinMode(masterpin, INPUT);
  pinMode(doorpin, INPUT);
  pinMode(pushbutton, INPUT);
  for (int i=0;i<4;i++)
    pinMode(busoutpin[i], OUTPUT);
  // turn the output pins off
    digitalWrite(busoutpin[i], LOW);
  buttonstate=0;
  doorstate=0;
  turnoff();
  // check for the push button ON or door switch ON
  while ((buttonstate==0) && (doorstate==0))
    // check the master switch again
    master=digitalRead(masterpin);
    delay (100);
    // check push button again
    pushbutton=digitalRead(pushbuttonpin);
    delay (100);
    if ((pushbutton==1) && (master==1))
      buttonstate=1;
    // check the door switch again
    door=digitalRead(doorpin);
    delay (100);
    if ((door==1) && (master==1))
      doorstate=1;
      buttonstate=1;
    // when door is open and master switch is off
    if ((door==1) && (master==0))
      doorstate=0;
      buttonstate=0;
  // stay in loop when the master id ON AND the push button is press
  while ((master==1)  && (buttonstate==1))
     delay (100);
     if ((master==1) && (buttonstate==1))
       // push button is press AND master is ON
       alternating();
    // check the door again
     delay(100);
     // the door is open with master on
       doorstate=1;
       alternating();
       motorson();
       alternating();
     // after the door was open and closing the door
     if ((door==0) && (doorstate==1))
       buttonstate=0;
   // turn off everythings when master is off or door is close
   if ((master==0) || (door==0))
    doorstate=0;
    buttonstate=0;
    motorsoff();
    turnoff();
// alternating red light routine
void alternating()
  digitalWrite(busoutpin[0], HIGH);
  digitalWrite(busoutpin[1], LOW);
  digitalWrite(busoutpin[0], LOW);
  digitalWrite(busoutpin[1], HIGH);
  delay (500);
// turn off everythings routine
void turnoff()
  for (int i=0; i<4;i++)
//deploy stop sign motor and crossing gate motor
void motorson()
   digitalWrite(busoutpin[2], HIGH);
   digitalWrite(busoutpin[3], HIGH);
//re-track back stop sign and crossing gate
void motorsoff()
   digitalWrite(busoutpin[2], LOW);
   digitalWrite(busoutpin[4], LOW);
Great, Thanks! Looks like some great switch logic here.
Yes if you get pulled over by a Ohio State Trooper it's a ticket no matter what!
I was able to put together some code with your help and lloyddean that works great!
Oh, I agree with you, I hear truckers don't like Ohio. ( I did drive on I-75 in 2001 with a 10 wheeler truck, Man, did I follow the speed limit to the letter...
Great... Happy to hear it. And please show you code for the others members can see it and learn from it.
Is there a place to post the code like a repository etc.?
Here as this is where the discussion is.
Ok here is the code. I may not have properly put the brackets where most do but for my sanity I like them right with the code they represent. This is just for one pushbutton and one led. I am going to try and work on adding another button and led for what I will call the right side in the code. I also want to add headlight pulse and brake light flash and steady. Later after this all works good I want to add some special functions plus some rgb show lights when parked.
  Button Turns on and off a light emitting diode(LED) connected to digital
   pin 13, when pressing a pushbutton attached to pin 2.
 CIRCUIT:
 * LED attached from pin 13 to ground(on board led)
 * pushbutton attached to pin 2 from ground
 * 10K resistor attached to pin 2 from positive
// constants won't change. They're used here to
// set pin numbers:
const int buttonPinLF = 2;     // the number of the pushbutton pin
const int ledPin =  13;      // the number of the LED pin
// variables will change:
int buttonState = 0;         // variable for reading the pushbutton status
{ // initialize the LED pin as an output:
  pinMode(ledPin, OUTPUT);
  // initialize the pushbutton pin as an input:
  pinMode(buttonPinLF, INPUT); }
    // read the state of the pushbutton value:
    buttonState = digitalRead(buttonPinLF);
    // check if the pushbutton is pressed.
    // if it is, the buttonState is Low:
    if (buttonState == LOW)       // turn LED on
  { for (int i=0;i<3;i++)         // flash 3 times & delay
  { digitalWrite(ledPin, HIGH);   // set the LED on
    delay(500);                   // wait
    digitalWrite(ledPin, LOW);    // set the LED off
    delay(500); }                 // wait
  delay(2000); }
  { // turn LED off:
    digitalWrite(ledPin, LOW); }
Look nice. A baby step ? Yes Code need some improvement ? Yes. Need more learning ? Yes. I hope you pla to buy a book call "Getting Started With Arduino". I have this book and it help me. Or this site at Page Not Found | Lulu It got a free pdf booklet.
