I have stripped out the web page serving bits and here is the code. A bit of background, I am trying to monitor 6 digital IOs using interrupts and display the counters for each on the LCD.
#include <EEPROM.h>
#include <SPI.h>
#include <Ethernet.h>
#include <LiquidCrystal.h>
const int DebounceDelay = 250;
const int ShowIPPin = 26;
const int Counter1Pin = 2;
const int Counter2Pin = 3;
const int Counter3Pin = 18;
const int Counter4Pin = 19;
const int Counter5Pin = 20;
const int Counter6Pin = 21;
const char QUOTE = 34;
const int LED1Pin = 13;
const int LED2Pin = 53;
byte MACAddress[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte IPAddress[4];
Server WebServer(80);
LiquidCrystal lcd(12, 11, 25, 24, 23, 22);
String MachineName1;
String MachineName2;
String MachineName3;
String MachineName4;
String MachineName5;
String MachineName6;
unsigned long Counter1 = 0;
unsigned long Counter2 = 0;
unsigned long Counter3 = 0;
unsigned long Counter4 = 0;
unsigned long Counter5 = 0;
unsigned long Counter6 = 0;
String CountersString;
Serial.println("Started");
GetIPAddress();
Ethernet.begin(MACAddress, IPAddress);
WebServer.begin();
pinMode(LED1Pin, OUTPUT);
pinMode(ShowIPPin, INPUT);
pinMode(Counter1Pin, INPUT);
pinMode(Counter2Pin, INPUT);
pinMode(Counter3Pin, INPUT);
pinMode(Counter4Pin, INPUT);
pinMode(Counter5Pin, INPUT);
pinMode(Counter6Pin, INPUT);
digitalWrite(ShowIPPin, HIGH);
digitalWrite(Counter1Pin, HIGH);
digitalWrite(Counter2Pin, HIGH);
digitalWrite(Counter3Pin, HIGH);
digitalWrite(Counter4Pin, HIGH);
digitalWrite(Counter5Pin, HIGH);
digitalWrite(Counter6Pin, HIGH);
attachInterrupt(0, Counter1Handler, FALLING);
attachInterrupt(1, Counter2Handler, FALLING);
attachInterrupt(2, Counter3Handler, FALLING);
attachInterrupt(3, Counter4Handler, FALLING);
attachInterrupt(4, Counter5Handler, FALLING);
attachInterrupt(5, Counter6Handler, FALLING);
lcd.begin(20, 4);
Client IncomingClient = WebServer.available();
String tmpCountersString;
boolean currentLineIsBlank = true;
char c;
String QueryString;
char WhichCounter;
int tmpPos = 0;
if (IncomingClient) {
while (IncomingClient.connected()) {
if (IncomingClient.available()) {
c = IncomingClient.read();
QueryString += c;
if (c == '\n') {
if (currentLineIsBlank) {
WebPage(IncomingClient);
else {
if ( QueryString.indexOf("ResetCounterValue") != -1 ) {
tmpPos = QueryString.indexOf("=") + 1;
WhichCounter = QueryString.charAt(tmpPos);
ResetCounter(IncomingClient, WhichCounter);
else if ( QueryString.indexOf("SetCounterInitialValue") != -1 ) {
Serial.println(" SetCounter");
else if (QueryString.indexOf("SetCounterName") != -1 ) {
Serial.println(" Name Counter");
QueryString = "";
if (c == '\n') {
else if (c != '\r') {
currentLineIsBlank = false;
delay(1);
IncomingClient.stop();
ShowIPAddress(digitalRead(ShowIPPin) == HIGH);
TimeToLCD(11, 0);
lcd.setCursor(0, 2);
lcd.print(CounterToString(Counter1));
lcd.setCursor(7, 2);
lcd.print(CounterToString(Counter2));
lcd.setCursor(14, 2);
lcd.print(CounterToString(Counter3));
lcd.setCursor(0, 3);
lcd.print(CounterToString(Counter4));
lcd.setCursor(7, 3);
lcd.print(CounterToString(Counter5));
lcd.setCursor(14, 3);
lcd.print(CounterToString(Counter6));
//if (Serial.available())
//ProcessSerialRequest();
void Counter1Handler()
static unsigned long LastInterruptTime = 0;
unsigned long InterruptTime = millis();
if (InterruptTime - LastInterruptTime > DebounceDelay) {
Counter1 ++;
LastInterruptTime = InterruptTime;
void Counter2Handler()
Counter2 ++;
void Counter3Handler()
Counter3 ++;
void Counter4Handler()
Counter4 ++;
void Counter5Handler()
Counter5 ++;
void Counter6Handler()
Counter6 ++;
void TimeToLCD(int Column, int Row)
int SecondsSinceReset = 0;
int HoursSinceReset = 0;
int MinutesSinceReset = 0;
SecondsSinceReset = millis() / 1000;
MinutesSinceReset = SecondsSinceReset / 60;
HoursSinceReset = MinutesSinceReset / 60;
//if ( MinutesSinceReset > 59)
// MinutesSinceReset = 0;
MinutesSinceReset = (MinutesSinceReset % 60);
lcd.setCursor(Column, Row);
if ( HoursSinceReset < 9)
lcd.print("0");
lcd.print(HoursSinceReset);
lcd.print(":");
if ( MinutesSinceReset < 10)
lcd.print("0");
lcd.print(MinutesSinceReset);
String CounterToString(unsigned long CounterValue)
String tmpCounterString;
String Result;
tmpCounterString = "000000";
tmpCounterString += CounterValue;
tmpCounterString = tmpCounterString.substring(tmpCounterString.length() - 6, tmpCounterString.length());
return tmpCounterString;
void WebPage( Client IncomingClient)
void ResetCounter(Client IncomingClient, char WhichCounter)
switch (WhichCounter) {
case '1' :
Counter1 = 0;
case '2' :
Counter2 = 0;
case '3' :
Counter3 = 0;
case '4' :
Counter4 = 0;
case '5' :
Counter5 = 0;
case '6' :
Counter6 = 0;
void ShowIPAddress(boolean BlankLine)
if ( BlankLine == true ) {
lcd.setCursor(0, 1);
lcd.print(" ");
else {
lcd.print("IP: ");
lcd.print(IPAddress[0], DEC);
lcd.print(".");
lcd.print(IPAddress[1], DEC);
lcd.print(".");
lcd.print(IPAddress[2], DEC);
lcd.print(".");
lcd.print(IPAddress[3], DEC);
void GetIPAddress()
for (int ILoop = 0; ILoop < 4; ILoop ++)
IPAddress[ILoop] = EEPROM.read(ILoop);
It compiles OK.
Robtillaart: I have looked at the code you linked and based my approach on that (modified for interrupt usage)
Z
