New to Arudino
I just ordered a Arduino Duemilanove Starter kit Beginner Full package from cuteDigi. Can you all recommend some books to read to get me started.
First off, what is your level of electronics knowledge (also include computer knowledge)?
I am a beginner, but very quick learner. I have been around computers over 2/3 of my life. I have built and repaired computers for quite some time. I am proficient with hardware and most software. I have built several small electronic projects in the past.
You should have no trouble getting into arduino then :slight_smile:
There are some manuals in the playground section: Arduino Playground - ManualsAndCurriculum
Thanks Cr0sh and raron
Do you know what Ohm's law is?
If not, then I suggest that you pick up the book "Basic Electronics" by Grob:
Get the hardcover, most recent edition as you can afford (a 20 year old edition is preferable to none). You will likely refer to it often as you work and learn. It is a textbook, often used in EE101-type courses at the university/college level. The majority of the "hows" and "whys" of electronics are covered. Theory of operation, mathematics and principles, component construction, usage in circuits (both at a theoretical "perfect" level and in practice) - all of that is covered, and more.
Beyond that, I would also recommend picking up all of the electronics books and such written by Forrest M. Mims III (especially the "Engineers Mini-Notebook's", as you can find them - they were originally published by Radio Shack back when they were a real electronics outlet, and not the shadow of a shadow of their former selves they are today):
http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Dus-stripbooks-tree&field-keywords=Forrest+M.+Mims+III&x=0&y=0
Those books mentioned are fine for general purposes; indeed, they should all be considered the "core curriculum" of electronics, if you will. However, your interests may be in a certain specific area of computers and electronics that you want to apply or experiment with the Arduino in. If this is the case, let us know - I am certain we may all be able to recommend further sites and reading toward this end.
Oh - I also want to mention a few other great sites I have had the pleasure to discover and utilize:
http://www.thebox.myzen.co.uk/Tutorial/Introduction.html
That's "Grumpy_Mike's" tutorial site - he's a regular contributor to the forums here; generally, if you have a question, and you post it on the forums, you'll get a response from him. His handle is "well earned" so-to-speak, but overall I have found his information solid and knowledgeable, despite this. I always respect his (among others here - if you want a list, PM me) opinion and advice when it comes to electronics and Arduino matters. Take heed!
http://www.kpsec.freeuk.com/
This is another great site for learning electronics basics; its great for reference. The only downside is that due to its geographical orientation (Britain/EU), it tends to use terms and other conventions in electronics that are different from what you would see in North America (ie, "earth" for "ground", "4K7" for "4.7 K", etc); plus part numbers are generally referenced to what is common to find in Europe. With that said, I have found it otherwise to be a great site to have bookmarked; I sometimes wish I could find a similar site with the same breadth of coverage geared toward North American conventions.
Good luck, and I hope all this helps...
:slight_smile:
Thanks Cr0sh. I just paced a big amazon order and book marked all the sights. This will definitely get me going.
This one is a great book/pdf, download here:
(The Complete Beginners Guide to the Arduino)
http://www.earthshineelectronics.com/files/ASKManualRev3.pdf
Thanks electrosys
Hi !
I've just visited this forum. Happy to get acquainted with you. Thanks.
I've learned alot from the guys from hardware to code. The spirograph was challenging but I got it done and now it don't get out as much as it used to.
