Hi!
Just started on my new arduino project.
I need help to figure out what the problem with my code is
The project consists of two files "MSTC_0_1_ino.ino" and "types.h"
"MSTC_0_1_ino.ino"
//Includes
#include <AFMotor.h>
#include "types.h"
//Objects
AF_DCMotor MotorLeft(4, MOTOR12_64KHZ);
AF_DCMotor MotorRight(3, MOTOR12_64KHZ);
//Constant values
#define MinRange 8;
#define MaxRange 200;
#define MinSpeed 0;
#define MaxSpeed 255;
#define PointTurn true;
#define DistanceClose 20;
//Debugging function
#define DEBUG true;
#ifdef DEBUG
#define DEBUG_PRINT(x) Serial.println(x);
#else
#define DEBUG_PRINT(x);
#endif
//Pin declaration
#define IRRangePin 0;
//Global values
Distances Distance = Unknown;
Actions Action = Stop;
int Speed;
void setup(){
DEBUG_PRINT("Motor test!");
#ifdef DEBUG
// MotorTest();
#endif
void loop(){
//kontrollera avstånd
MapRangeToDistance(ReadRange());
DEBUG_PRINT(ReadRange());
//vänta på kommando
GetAction();
//kontrollera värden
//mappa om avståndet till hastighet
//agera
//Rapportera värden
void GetAction(){
boolean read = false;
while(!read){
#ifdef DEBUG
if(Serial.available() > 0){
switch(Serial.read()){
case 'f':
Action = Forward;
read = true;
case 'r':
Action = Right;
read = true;
case 'l':
Action = Left;
read = true;
case 'b':
Action = Backward;
read = true;
case 's':
Action = Stop;
read = true;
default:
DEBUG_PRINT("Not a valid command!");
#else
//TODO IRReciverCode
Action = Stop;
read = true;
#endif
//Make the motors beep to check that they are connected.
void MotorTest(){
Speed = 50;
SetSpeed();
Action = Forward;
Act();
delay(200);
Action = Stop;
Act();
delay(200);
//Set Distance acording to Range
void MapRangeToDistance(int Range){
if(Range > DistanceClose) Distance = Far;
else if((Range <= MaxRange) && (Range > DistanceClose)) Distance = InRange;
else if(Range <= DistanceClose) Distance = Close;
else Distance = Unknown;
//Make shure that range is in a valid range then map it from that range to the speed range
void MapRangeToSpeed(int Range){
//result = a > b ? x : y;
if (Range < MinRange) Range = MinRange;
else if (Range > MaxRange) Range = MaxRange;
Speed = map(Range, MinRange, MaxRange, MinSpeed, MaxSpeed);
//Update motor speed
void SetSpeed(){
MotorLeft.setSpeed(Speed);
MotorRight.setSpeed(Speed);
//Returns the distance read from the ir range finder
int ReadRange(){
float volts = analogRead(IRRangePin)*0.0048828125; // value from sensor * (5/1024)
return int(65*pow(volts, -1.10)); // worked out from graph 65 = theretical distance / (1/Volts)S - luckylarry.co.uk
//Act upon distance read and desired command.
void Act(){
// if(((Distance == Close) || (Distance == Unknown)) && (Action == Forward)) Action = Stop;
switch(Action)
case Forward:
MotorLeft.run(FORWARD);
MotorRight.run(FORWARD);
case Right:
if (PointTurn) MotorRight.run(BACKWARD);
case Left:
if (PointTurn) MotorLeft.run(BACKWARD);
case Stop:
MotorLeft.run(RELEASE);
MotorRight.run(RELEASE);
"types.h"
enum Distances {
Unknown,
Far,
InRange,
Close
enum Actions{
Forward,
Right,
Left,
Backward,
Stop
error codes
MSTC_0_1_ino.cpp: In function 'void MapRangeToDistance(int)':
MSTC_0_1_ino:105: error: expected)' before ';' token MSTC_0_1_ino:105: error: expected primary-expression before ')' token MSTC_0_1_ino:105: error: expected
;' before ')' token
MSTC_0_1_ino:106: error: 'else' without a previous 'if'
MSTC_0_1_ino:106: error: expected)' before ';' token MSTC_0_1_ino:106: error: expected
)' before ';' token
MSTC_0_1_ino:106: error: expected primary-expression before ')' token
MSTC_0_1_ino:106: error: expected;' before ')' token MSTC_0_1_ino:106: error: expected primary-expression before ')' token MSTC_0_1_ino:106: error: expected
;' before ')' token
MSTC_0_1_ino:107: error: 'else' without a previous 'if'
MSTC_0_1_ino:107: error: expected)' before ';' token MSTC_0_1_ino:107: error: expected primary-expression before ')' token MSTC_0_1_ino:107: error: expected
;' before ')' token
MSTC_0_1_ino:108: error: 'else' without a previous 'if'
MSTC_0_1_ino.cpp: In function 'void MapRangeToSpeed(int)':
MSTC_0_1_ino:114: error: expected)' before ';' token MSTC_0_1_ino:114: error: expected primary-expression before ')' token MSTC_0_1_ino:114: error: expected
;' before ')' token
MSTC_0_1_ino:115: error: 'else' without a previous 'if'
MSTC_0_1_ino:115: error: expected)' before ';' token MSTC_0_1_ino:115: error: expected primary-expression before ')' token MSTC_0_1_ino:115: error: expected
;' before ')' token
MSTC_0_1_ino:116: error: expected)' before ';' token MSTC_0_1_ino:116: error: expected primary-expression before ',' token MSTC_0_1_ino:116: error: expected primary-expression before ',' token MSTC_0_1_ino:116: error: expected primary-expression before ',' token MSTC_0_1_ino:116: error: expected primary-expression before ')' token MSTC_0_1_ino:116: error: expected
;' before ')' token
MSTC_0_1_ino.cpp: In function 'int ReadRange()':
MSTC_0_1_ino:127: error: expected)' before ';' token MSTC_0_1_ino:127: error: expected primary-expression before ')' token MSTC_0_1_ino:127: error: expected
;' before ')' token
MSTC_0_1_ino.cpp: In function 'void Act()':
MSTC_0_1_ino:142: error: expected)' before ';' token MSTC_0_1_ino:142: error: expected primary-expression before ')' token MSTC_0_1_ino:142: error: expected
;' before ')' token
MSTC_0_1_ino:146: error: expected)' before ';' token MSTC_0_1_ino:146: error: expected primary-expression before ')' token MSTC_0_1_ino:146: error: expected
;' before ')' token
I've doubblechecked the syntax without finding any obvious errors.
Since I've been at it for 6 hours now I decided to ask for help.
Added the project for download.
Thanks in advance //Henke
MSTC_0_1_ino.rar (1.58 KB)
