New to code and need help with old libraries
I'm new to Arduino and coding. I have code I found on a forum that is used to communicate via CAN bus using a Nano etc. This code was written in 2016 and it's giving errors in regards to CANid. Is there any way someone could help edit this code to work with the Atmega328 type boards? I'm quite sure libraries have changed and some of this will be self explanitory however it is way above my pay grade at the moment. Any help would be greatly appreciated.
Regards,
-Vern`
// from rectifier : (requests for logins)
// 05014400 + ser nr + 00 00 from rectifier  : HELLOOW where are you ! rectifier sends 05014400 and 6 bytes serial number and followed by 00 00 (login request)
// 0500xxyy + 1B + ser nr + 00 is send during normal voltage every second. xxyy is the last 2 bytes from the serial number
// after either of these send 05004804 every 5 seconds ! to keep logged in. rectifier does not send login requests so after 10 second the numbers stop until 05014400 is sent
// from rectifier : (status messages)
// 0501400C + status data : walkin and below 43 volts (error) and during walk-out (input voltage low)
// 05014010 + status data : walkin busy
// 05014004 + status data : normal voltage reached
// 05014008 + status data : current-limiting active
// send TO rectifier (act as controller)
// 05004804 + ser nr + 00 00 from controller : send 05004804 and 6 bytes ser number followed by 00 00
// 05FF4004 controller sends current and voltage limits (last 4 is 5 sec walk-in, for 60 second walk-in use 05FF4005)
// 05FF4005 controller sends current and voltage limits (last 5 is 60 sec walk-in, for 5 second walk-in use 05FF4004)
#include <mcp_can.h>
#include <mcp_can_dfs.h>
#include <SPI.h>
#include <LiquidCrystal.h>
const int SPI_CS_PIN = 10;
word maxcurrent = 0x64;                                                              // set initial maxcurrent to 10A output
unsigned char len = 0;
unsigned char serialnr[8];
int msgreceived;
MCP_CAN CAN(SPI_CS_PIN);                                                             // Set CS pin for CANBUS shield
LiquidCrystal lcd(1, 3, 4, 5, 6, 7, 8);                                              // LiquidCrystal(rs, rw, enable, d4, d5, d6, d7)  or LiquidCrystal(rs, enable, d4, d5, d6, d7)
void setup()        // Initialisation routine
 pinMode(A0, INPUT);        // Set pin A0 to input (pushbutton)
 digitalWrite(A0, HIGH);                                                             // activate pull-up on A0
 pinMode(9, OUTPUT);        // Set pin 9 to output (backlight of the LCD)
 digitalWrite(9, HIGH);                                                              // Backlight enable
  lcd.begin(16, 2);        // splash screen on LCD
  lcd.print("Flatpack Charger");
  lcd.setCursor(0, 1);
  lcd.print("Made by RHO");
START_INIT:
    if(CAN_OK == CAN.begin(CAN_125KBPS))                                              // init can bus : baudrate = 125k !!
        lcd.setCursor(0,0);
        lcd.print("CAN BUS init OK!");
        delay(100);
        lcd.setCursor(0,0);
        lcd.print("CAN BUS init Fail");
        lcd.setCursor(0,1);
        lcd.print("Init CAN BUS again");
        delay(100);
        goto START_INIT;
    lcd.clear();
void loop()        // main program (LOOP)
  unsigned char buf[8] ;
  if(CAN_MSGAVAIL == CAN.checkReceive())                                              // check if data coming
        CAN.readMsgBuf(&len, buf);                                                    // read data,  len: data length, buf: data buf
        INT32U canId = CAN.getCanId();                                                // read the CAN Id
    if(canId==0x05014400)                                                             //this is the request from the Flatpack rectifier during walk-in (start-up) or normal operation when no log-in response has been received for a while
         for(int i = 0; i<8; i++)
         serialnr[i]=buf[i];                                                          // transfer the message buffer to the serial number variable
         CAN.sendMsgBuf(0x05004804, 1, 8, serialnr);                                  //send message to log in (DO NOT ASSIGN AN ID use 00)
         msgreceived++;                                                               // increase the variable "msgreceived"
         unsigned char stmp7[8] = {lowByte(maxcurrent), highByte(maxcurrent), 0x44, 0x16, 0x44, 0x16, 0x3E, 0x17};    // set rectifier to maxcurrent 57,0V (16 44) and OVP to 59.5V (17 3E) qnd long walk-in 4005 or short walk in 4004
         CAN.sendMsgBuf(0x05FF4005, 1, 8, stmp7);        //(last 4 in header is for 5 sec walkin, 5 is for 60 second walkin)
    else if(canId==(0x05000000+256*buf[5]+buf[6]))                                    //if CANID = 0500xxyy where xxyy the last 2 digits of the serial nr
        for(int i = 0; i<6; i++)
            serialnr[i]=buf[i+1];                                                     // transfer the buffer to the serial number variable (neccesary when switching the CAN-bus to another rectifier while on)
        unsigned char serialnr[8] = {buf[1], buf[2], buf[3], buf[4], buf[5], buf[6], 0x00, 0x00};                     //this is the serial number of the unit which is covered in the request (unit announces its serial number)
        CAN.sendMsgBuf(0x05004804, 1, 8, serialnr);        //send message to log in (DO NOT ASSIGN AN ID) use 00
        msgreceived++;
    else if((canId==0x05014004)or(canId==0x05014008)or(canId==0x05014010)or(canId=0x0501400C))                        // these are the status messages (05014004 is not current-limiting, 05014008 is current limiting 05014010 = busy with walkin, 0501400C in input voltage low)
           msgreceived++;        // record number of messages received
           if(msgreceived>40)
             msgreceived=0;
             CAN.sendMsgBuf(0x05004804, 1, 8, serialnr);                                                              //send message to log in every 40 messages (DO NOT USE ID NR, USE 00) this because during walk-in the 0500xxyy is not send and the rectifier "logs out" because of no received log-in messages from controller
             msgreceived++;
           lcd.setCursor(0, 0);                                                        //show data on the LCD screen 0x050140yy 0xAA 0xBB 0xCC 0xDD 0xEE 0xFF 0xGG 0xHH
           lcd.print("T=");
           lcd.print(buf[0]);                                                          // 0xAA = Temperature in
           lcd.print("/");
           lcd.print(buf[7]);                                                          // 0xHH = Temperature out
           lcd.print("   ");
           lcd.setCursor(8,0);
           lcd.print("I=");
           lcd.print(buf[2]*256*0.1+buf[1]*0.1);                                       // 0xBB = Current Low Byte, 0xCC = Current High byte. Current in deciAmps (*0.1 Amps)
           lcd.print("  ");
           lcd.setCursor(8,1);
           lcd.print("Vo=");
           lcd.print(buf[4]*256*0.01+buf[3]*0.01);                                     // 0xDD = Voltage out Low Byte, oxEE = Voltage out High Byte. Voltgae in centivolts (*0.01 Volt)
           lcd.print("  ");
           lcd.setCursor(0,1);
           lcd.print("Vi=");
           lcd.print(256*buf[6]+buf[5]);                                               // 0xFF = Voltage in Low byte, 0xGG = Voltage in High byte. Voltage in Volts (because voltage is below 255 Volts, high byte is always 0)
           lcd.print("  ");
           if((digitalRead(A0)==0))                                                    //read digital pin Analog0 and if it is high (pushbutton is pressed)
             maxcurrent = maxcurrent + 100;                                            // raise maxcurrent with 10 A
             if(maxcurrent > 400)                                                      // to be able to lower the current with one button, if the maxcurrent > 40 the current is reset to 10
               maxcurrent =100;
             digitalWrite(9,HIGH);        // switch on the backlight
             CAN.sendMsgBuf(0x05004804, 1, 8, serialnr);        // send message to log in (DO NOT ASSIGN AN ID) use 00
             CAN.sendMsgBuf(0x05FF4005, 1, 8, stmp7);        // (last 4 in header is for 5 sec walkin, 5 is for 60 second walkin)
             lcd.setCursor(0, 0);        // announce chosen current on LCD
             lcd.print("Current set to  ");
             lcd.print(maxcurrent*0.1);
             lcd.print(" Amp        ");
        lcd.setCursor(0,0);                                                            // if the canId is unknown
        lcd.print(canId,HEX);                                                          // show the can Id and the message on the LCD
        lcd.setCursor(0,1);
        for(int i = 0; i<len; i++)
          if( buf[i] < 0x10){ lcd.print("0");} lcd.print(buf[i],HEX);                  // send a leading zero if only one digit
        delay(1000);        // show the message for 1 second and then continue
  END FILE
Please insert the error messages in the forum using the code tags
You could use INPUT_PULLUP rather than writing HIGH to an INPUT pin.
What's a Nano etc? :stuck_out_tongue:
What is your end goal? Describe the project. To get a Nano talking to other micro processors, talk to automotive components, etc?
C:\Users\IOT_SUP\Documents\Arduino\Remmie1972_sketch_may9a_Leonardodisplay\Remmie1972_sketch_may9a_Leonardodisplay.ino: In function 'void loop()':
C:\Users\IOT_SUP\Documents\Arduino\Remmie1972_sketch_may9a_Leonardodisplay\Remmie1972_sketch_may9a_Leonardodisplay.ino:87:28: error: 'class MCP_CAN' has no member named 'getCanId'; did you mean 'getGPI'?
                            getGPI
exit status 1
Compilation error: 'class MCP_CAN' has no member named 'getCanId'; did you mean 'getGPI'?
I appreciate your patience. I'm new to posting code online etc...
Errors like this usually indicate that you have included the wrong (or wrong version) of the library.
Post links to where you found the code, and where you found the library.
I'm using this old code to communicate via CAN bus to 3000 watt Eltek rectifiers. I like the functionality this code provides and its ability to change amperage with a button press. "Nano" is a reference to Arduino Nano...There is provision for a display within the code as well as the ability to negotiate hardware serial number data.
The above link to library can be found at the following link to a forum post: ULtra Compact 1800W charger + Eltek programming | Page 2 | Endless Sphere
This post was written in 2015 so after review of the library files I could find no reference to "CANid"
I believe the code will need some updating...
I hear ya...I'm quite sure there is some great talent here that could update the code. I'm learning as I go but its going to take me a few classes before I get heavy into this stuff...
Your code compiled fine for me.
Used libraries:
Using library CAN_BUS_Shield-master at version 1.0.0 in folder: T:\Arduino\libraries\CAN_BUS_Shield-master
Using library SPI at version 1.0 in folder: T:\Arduino\hardware\arduino\avr\libraries\SPI
Using library LiquidCrystal at version 1.0.5 in folder: T:\Arduino\libraries\LiquidCrystal
Sketch uses 7696 bytes (25%) of program storage space. Maximum is 30720 bytes.
I did not make any corrections other than replacement INT32U to uint32_t in the line:
Wow, thanks for the reply. It looks as if you may have referenced older libraries?
Will you show me where to find or provide a download link for the CAN_BUS_Shield-master version 1.0.0?
Unbelievable.....
I moved all files out of my libraries and added the following:
After making the changes to the code....everything compiled.
Thank you very much for the help with this...!
