new to coding and had some issues while writing project 2 spaceship code
I get the error Arduino: 1.8.5 (Windows 10), Board: "Arduino/Genuino Uno"
spaceship:1: error: expected unqualified-id before numeric constant
1 int switchState = 0;
spaceship:2: error: expected unqualified-id before numeric constant
2 void setup(){
spaceship:8: error: expected unqualified-id before numeric constant
8 void loop(){
and my code is:
2 void setup(){
3 pinMode(3,OUTPUT);
4 pinMode(4,OUTPUT);
5 pinMode(5,OUTPUT);
6 pinMode(2,INPUT);
7 }
8 void loop(){
9 switchState = digitalRead(2);
10 // this is a comment
11 if (switchState == LOW) {
12 // the button is not pressed
13 digitalWrite(3, HIGH); // green LED
14 digitalWrite(4, LOW); // red LED
15 digitalWrite(5, LOW); // red LED
16 }
17 else { // the button is pressed
18 digitalWrite(3, LOW);
19 digitalWrite(4, LOW);
20 digitalWrite(5, HIGH);
21 delay(250); // wait for a quarter second
22 // toggle the LEDs
23 digitalWrite(4, HIGH);
24 digitalWrite(5, LOW);
25 delay(250); // wait for a quarter second
26 }
27 } // go back to the beginning of the loop
I would be very happy to figure out the issue.
You should not have line numbers.
...R
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
What IDE are you using?
If you need line numbers the Arduino IDE can put them in the margin of your code.
Thanks.. Tom.. :slight_smile:
same here
heres my code
void setup(){
pinMode(3, OUTPUT);
pinMode(4, OUTPUT);
pinMode(5, OUTPUT);
pinMode(2, INPUT);
// Hello
// toggle the LEDs
} // go back to beginning of the loop
You are missing the { to open the loop() code block.
Read the forum guidelines to see how to post code.
In the future post the entire error message. Paraphrasing leaves out important information.
