New to IoT need help to start project. SHT10
Hi all.. Im new to IoT but want to learn, I hope you can help me getting started with my project.
Maybe the project is simply, but not for me :-).
I want to place a Mesh-protected Weather-proof Temperature/Humidity Sensor - SHT10 (SHT-10 Mesh-protected Weather-proof Temperature/Humidity Sensor : ID 1298 : $49.95 : Adafruit Industries, Unique & fun DIY electronics and kits) in my summerhouse.
The summerhouse has no WiFi to send data. During my research I discovered Sigfox which can send data without a simcard and without internet.
So what I want to make in my project:
A device that can send data about humidity and temperature to me with the Sigfox network (or something similar) using the SHT10 (as above). My research led me to belive that I need a arduino to do the job - could the ARDUINO MKR FOX 1200 do the job?
And what else do I need to get this project started? Like power supplies, cases - other things?
I really hope you guys can help me!
Matiasow:
The above does not sit well the the subject of your post, it may also be untrue, and a better explanation of what you want to do might be in order.
There are some ways of sending data from a sensor so that its data is available on the internet, without the sensor itself needing an Internet connection.
The first is Sigfox, which is a subscription service, you pay.
The second is The Things Network, which is a free to use service with a fair access policy.
There may be other methods, not sure.
Both the above require access to a local gateway within a couple of kilometres, you would need to check they are available for your area.
