New to programming
I need help programming my project the input is a gyro sensor and light sensor and output is the buzzer.When the gyro sensor detect the X,Y,Z axis change it will activate the buzzer same as the light sensor when the light sensor is not block it will NOT activate the buzzer.Thanks in advance
Welcome to the forum. You can get plenty of help here but are expected to put in some effort yourself and don't ask the same question in more than one section of the forum.
What have you tried so far ? Can you read the sensors ? What sensors are they ?
What do you mean, "same as the light sensor"? Because you have an non punctuated run on sentence, it's hard to decipher exactly what the requirement is.
You need help programming?
Or you need someone to write your code for you?
If it is the first case, post what you have so far (code and schematic), and we can help you with anything that might not work.
If it is the second case, hire someone to do it for you.
Benji:
But you will still have to explain your requirements to them clearly.
Ok currently i'm trying to figure out on my own first by doing more research if i need help ill update you guys thanks
While doing research, please also try to read up on punctuation. It's pretty difficult to read your posts.
